I forgot to update this thread with the stroker combo that has been in my street/strip car for 5 seasons now....lol.
Car67 Barracuda
Weight ~3200
Gear ratio4.10
Tire diameter28, Hoosier QTP
RPM through trap ~ 6000 1/8, ~6500 1/4
MPH through traps ~ 100 1/8, ~123+ 1/4
ET6.76 1/8 (~ 10.60s ¼) with 1.45 60
Engine CID410
Head TypeEdelbrock
Valve size2.02, 1.60
Head WorkStage II port from Ryan at Shady Dell, 57cc combustion chambers.
Cam ManufacturerComp Cams (XR286R)
Cam specs at 50248/254
Carb type and size750 dp, Proform main body
PV Ratingblocked
Jet sizes91 square
Plug number and brandNGK, R5671A-7
Intake Manifold TypeVictor
Piston MakeDiamond
Compression Ratio10.89:1, pump gas
Trans type727
Trans ModsFull manual, Turbo Action valve body
Convertor typePTC 8
Convertor stall5000
Trans BrakeNo thanks, please dont brake the trans
Drive shaft stock or aftermarketcustom
Initial timing34
Total timing34
Total advance at what RPMLocked out
Rear end typeMO875 fabricated housing, back-braced, 35 spline axles, spool, full Caltrac setup (links, monos, shocks).
