Please do something about that tripod engine stand.Finally got the bottom end all together. With some super happy help.
???Please do something about that tripod engine stand.
It comes off tomorrow and into the Cradle again. I never move the stand with the engine on it.They are telling you that the 3 castered stand might tip over if not very careful. I welded a bar with two casters across the single caster on the front, it's much more stable now.
Thanks! That helps a lot!re setting ride height with coilovers. the shock should be 1/3 compressed at ride height so it has 2/3 bump and 1/3 rebound. if you set ride height at 1/2 of the shock travel it will bottom out a lot, unless the springs are too hard and then you'll likely get the springs rattling loose on full extension.
neil.
I'm more of a believer the shock can ride pretty much in the middle of the stroke with the spring compressing 25 to 33%.
Nice progress! I keep comin in here when this thread pops up lookin for 44dds. Dangit.
