Wilcap is awesome, locally owned..You get what you pay for...They sell an aftermarket bell that bolts to the front pump. Pat at Wilcap.com should be able to explain it better than I. Pat is a great guy and right sown the street from me.
I know you don't like filler...Some PCL Polyprimer with a small spray pattern ,two coats...should fill those low spots..Right door
Looks like sometime in its life someone slammed the door while holding the handle and kinked the metal. So I am attempting to get the metal to go back where it came from, its seems to remember mostly.
Keep tapping and tapping and tapping
IT'S Touchy, on mixing ..It uses "MEKP/ A.K.A fiberglass hardener" it fills quickly,leave the coats thin... Just offering,an option...
do you have part numbers for those switches? i can't find that adjustment range
Let's see some footage of Ol' Yellar!!!
Wagner PCV installed and dialed in. Maybe I just like to tinker but I believe the valve has helped my choppy cam idle some what. Being an automatic car it surged allot at idle in gear, and now it is very minor. I tried single mode first since my vac. is around 7-8 and didn't really notice any difference so I tried dual mode and that did it.
Maybe a custom torque converter someday since I am doubting my 1,900 stall converter is doing a good job. But that was all I could afford.
Absolutely, a PCV valve, has an effect on idle speed and off throttle response.Wagner PCV installed and dialed in. Maybe I just like to tinker but I believe the valve has helped my choppy cam idle some what. Being an automatic car it surged allot at idle in gear, and now it is very minor. I tried single mode first since my vac. is around 7-8 and didn't really notice any difference so I tried dual mode and that did it.
I'm dying to remove the Limelight paint from my car and see the original F8 green underneath. How exactly did you remove the blue paint from the deck lid to get to the original bronze color?Trunk lid sanded down to the original bronze, if only the the whole would clean up like this I would leave it. It was painted blue over the bronze at one time, then primerView attachment 1714968149 . I love patina.
I used a fresh razor blade believe it or not. A old timer came by my shop and told me that trick, hard on the curved edges but possible. Then I color sanded the rest. Wish I could have done the whole that way but where any body work was done I wanted to fix and prime again for now until I can afford the paint.I'm dying to remove the Limelight paint from my car and see the original F8 green underneath. How exactly did you remove the blue paint from the deck lid to get to the original bronze color?
Thanks I will check out the previous postI used a fresh razor blade believe it or not. A old timer came by my shop and told me that trick, hard on the curved edges but possible. Then I color sanded the rest. Wish I could have done the whole that way but where any body work was done I wanted to fix and prime again for now until I can afford the paint.
Go back to #66 you can see where I was doing the roof.
