SwingerLSX75
Got the rear end back, got it cleaned up and painted. A buddy helped swapped out the 3.73 gearset for the 3.55's. Got the axle bearings and seal installed and the moser 1350 yoke assembly. Then I got her back under the car with the clamp on style perches from speedway. Those however are going to take a little more massaging to get right. And it looks like there is a shot I can reuse the driveshaft I just had made and just put 1350 end on it and throw it back under the car and be good to go. So less downtime there. Should hopefully have the rear buttoned up in the next day or so and have it back on the ground with the right pinion angle and stuff so I can knw for sure what my center to center is and hopefully get the new ends on in a week or so, and have it fired back up this coming weekend.
