I'm sure I read another build thread on a rhd Cuda vert here on FABO. Might be worth a search.
Cley
Cley
Unfortunately its literally just the shell. The seller is a Scrap Metal man and sometimes gets his hands on odd-balls he's asked to come and get rid off. Supposedly the owner died before he could restore it. He stripped it down and this is as far as he got. Unfortunately the boxes of parts has been lost, most likely thrown away.
Restoring it is gonna be an issue, might have to import another one from the US at some point to swap everything over.
There are a couple of members on here that have them. Maybe one of them will be some help @moparownr
My RHD Barracuda
That steering setup is really interesting. I'd love to see a closer pic of the steering box.
If that's the case and it's a 68 up. The vin will be on the dash frame. That part looks like it's missing. You prob need to contact the person who sold it to junk dealer.
Under hood fender data plate has the full vin stamped in it on the bottom row. If it's a 69 the last 8 of the vin are also stamped on the top LH side of the radiator support, and on the LH side trunk weatherstrip rail, under the weather stripping.
Last 8 on the vin reads 9Bxxxxxx
9 for 69
B for dodge main Hamtramck Michigan. May be a different digit if built in California however I dont think any A body cudas were built in california.
My stampings on my 69 read B9xxxxxx on both panels, however the vin reads 9Bxxxxxx not really a big deal.
Hopefully your data plate is there, however the numbers can be pieced together if you have a 69 that's the year they stamped the last 8 of the vin in the body in those 2 places
vin should read BH27F9Bxxxxxx
B barracuda
H high line
27 convertible
F 318V8 (D in this spot if a 273V8)
9 model year 1969
B Hamtramck Michigan
xxxxxx last 6 is sequence code.
Theres ways of getting repop vins. Not sure of the hoops you got to jump through though. Heres one on evilbay. The rosette rivets are about $25 a pair.
The only number that's an iffy on the vin is the engine code. Not sure if the 273 V8 was the only export engine in 1969 on export barracudas, or if the 318 V8 was offered on 1969 export barracudas the 5th digit is either an F or a D. Both used the same K frame and motor mounts, however if the data plate is on the inner fender, for 69 up the last row of digits are the full vin.
You could take a pic of the tag and post it here if you want it decoded but I would blank out the last 8 digits of the vin # stamped on it.
Again this only works if it's a 69 up. That's when they started stamping the last 8 digits of the vin on the top LH side of the radiator support, and top LH side of the trunk drip rail under the weatherstrip. That may be on the RH side on this car like the vin is. If it's a 67 or 68 the numbers wont be the last 8 of the vin.
Does the car have the fender tag on it? I would try to find the seller of the car. There may be a shed full of parts from it somewhere. Who knows, they may give it all to you to haul it off. That would save you some serious coin trying to hunt down a lot of the hard to find pieces.
trigger_andy
Heres proof that nothing ever gets lost or disappears on the internet. I found this on a UK cars website. I do believe with almost 100% certainty that this is yours before the dissassembly occured. The colour and wheels are a match. It was a 318 car, with white interior, and is a 1969 model. I was hoping that sale ad would have had the vin number. BTW did you get the car, maybe find out who prev owner was, maybe get the rest of the parts?
All verts had power tops. Most of that mechanism to power it can be had new from Auto Metal Direcr and other sources. The hydraulic actuators can be rebuilt.
Verts had different wheel houses, and also had torque boxes tying the front and rear subframe to the rockers better. Imthe doors and door jambs had wedges to prevent the doors from being floppy from cowl shake. I would recommend adding subframe connectors to it. You can PM me, and I will give you a better lowdown on how to do that inexpensively and also tobe able to keep the chassis square.
Best of luck to you on restoring such a rare beast. Hopefully you can find the rest of the needed parts. A lot of the pieces minus the RHD specific bits are common cuda and A body stuff. Maybe members here can help.
It's pretty easy. Click on my screen name, and a drop down menu pops up. Has option to "start conversation". Click on that and type in the heading you want for the message, then fire away with your questions. I dont own a vert, but when you open the doors theres wedges that hold them tight into the jamb when closed so they dont shake up and down real bad when on a rough road. If your replacement door is from a hardtop, you will need to modify it for the door wedge. Ditto for the rear wheel houses. The trunk drops and trunk floor and main floor is the same as a hardtop though.
