Rrrrrrr, need help on this one.
Electrical and Ignition
  1. pearljam724
    pearljam724 Well-Known Member
    380
    120
    Aug 29, 2019
    United States
    Local Time:
    8:15 AM
    I just bought my car a few weeks ago. Car was running fine. For no reasonable explanation the in-line 40 fuse started blowing. I put a new fuse in. Everything powered back up. I attempt to start the car. It cranks for long as I want, but will not fire. As soon as I attempt to shut ignition key off. The fuse blows. I blew 10 fuses until I discovered a points condenser attached to negative terminal of coil. But, this distributor has been converted to electronic. I ran out of fuses before I removed the condenser thinking it shouldn’t be on there. Regardless, the car wasn’t blowing fuses prior to last couple days. I have same exact set up on a B body car and there is no condensor. So, I removed it. I’m usually pretty good at diagnosing problems. But, I’m going to need help on this one. I have no clue, why the fuse continues to blow now when I only attempt to start the car ?
  2. Dana67Dart
    Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
    4,568
    2788
    Jul 16, 2017
    Northern Colorado
    Local Time:
    6:15 AM
    "condenser" is a noise suppressor, probably not the issue.
    We need a lot of info to help you.
    What year?
    What engine?
    What modifications?
    Why is there a 40 amp in line fuse?
    Where does the fuse go?
    What have you done to diagnose it?
    • Agree Agree x 2
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      61,610
      33561
      Jun 7, 2010
      Georgia
      Local Time:
      8:15 AM
      So I guess we're just supposed to know make and model, engine, "what the hell" circuit you're talking about. "and all that"
      • Like Like x 1
      • kursplat
        kursplat FABO Gold Member FABO Gold Member
        2,968
        1948
        Aug 24, 2010
        so cal
        Local Time:
        5:15 AM
        Rrrrrrr, need help on this one...we all will without the wiring diagram and a host of other items
      • 318willrun
        318willrun Utube channel 318willrun
        14,873
        15645
        Sep 13, 2013
        I'm here
        Local Time:
        7:15 AM
        Sounds like the long blue wire is crossed with the short yellow wire. Make sure they are not touching.
        • Like Like x 1
        • Agree Agree x 1
        • pearljam724
          380
          120
          Aug 29, 2019
          United States
          Local Time:
          8:15 AM
          73 / 318 engine. Bone stock. The previous owner installed an inline 30 amp fuse where the fusible link typically goes. I noticed the car would lose all power at times. When it did, if I removed the fuse and reinstalled it. The car would power back up. But, it got to the point it would blow immediately. I replaced the inline fuse with a slightly heavier gauge one and installed a 40 amp fuse. It powers up every time. But, blows when I attempt to turn ignition key off when attempting to start it. I haven’t done anything to diagnose it. Because I don’t know where to start looking. I looked under the hood at most wiring and nothing appears to be a problem ?
        • pearljam724
          380
          120
          Aug 29, 2019
          United States
          Local Time:
          8:15 AM
          Which wires are these and where are they located ?
          • Like Like x 1
          • 318willrun
            14,873
            15645
            Sep 13, 2013
            I'm here
            Local Time:
            7:15 AM
            Exactly. LOL... helps to be descriptive. I was throwing out a pun at you for the lack of info we had to go on in your first post. :)
            :thumbsup:
            • Thanks! Thanks! x 1
            • 67Dart273
              67Dart273 FABO Gold Member FABO Gold Member
              43,401
              10958
              Oct 14, 2010
              Idaho
              Local Time:
              5:15 AM
              The condenser on the coil should be connected to POSITIVE side of coil. It is there to supress radio noise. I would indeed remove it until you find this cause.
              40a is likely not large enough. You have any idea how large your alternator is? Output current that is?
              I have few ideas. This is weird.
              So it still does not start? You have a test light? Some alligator clip lead "test leads?" How about a multimeter. We can make a few checks
              • Like Like x 1
              • pearljam724
                380
                120
                Aug 29, 2019
                United States
                Local Time:
                8:15 AM
                I have most necessary tools. Multimeter, etc. The alternator is probably 60 amp. Most are. No mistake, condensor was attached to negative side of coil. Previous owner replaced coil not long ago and I believe he hooked the condenser up incorrectly. Based on he didn’t know how to fix basic stuff. Kickdown linkage, 2 barrel carburetor choke adjustment, etc.
                But, the car ran fine. As far as starting it and it idling, etc.
              • Dana67Dart
                4,568
                2788
                Jul 16, 2017
                Northern Colorado
                Local Time:
                6:15 AM
                What does your ammeter do right before the fuse blows.
                In 67 the fusable link goes from the starter thru the firewall to the ammeter then to the battery charging cir of the alternator and to the ignition switch and to the headlight switch.
                A short anywhere in those cirs would blow a fuse, but 40 amp dead short is hard on 18 gauge wires so I would expect you will find wires melted together.
              • kursplat
                2,968
                1948
                Aug 24, 2010
                so cal
                Local Time:
                5:15 AM
                especially x10
              • j par
                j par Well-hung Member
                23,527
                11988
                Jul 2, 2014
                Portland Oregon
                Local Time:
                5:15 AM
                Post some pictures and point at stuff they're worth a thousand words...
              • pearljam724
                380
                120
                Aug 29, 2019
                United States
                Local Time:
                8:15 AM
                No wires are melted together. The inline fuse runs from the ignition relay attached on side of inner fender, by the battery. To the bulkhead middle connector. I didn’t take notice of what the ammeter does. When I get more fuses, I will check.
              • 67Dart273
                43,401
                10958
                Oct 14, 2010
                Idaho
                Local Time:
                5:15 AM
                Here is one thing you could try. You claim that if you operate the starter then shut off the key, the fuse blows. Try this. Obtain a large wattage bulb. Like an old headlight or a stop/ tail lamp (1157, etc) Disconnect battery ground and hook the lamp in series. You will not be able to operate the starter. But mimic it. Twist the key to "start". This should cause the test bulb to light brightly. Let off the key to "run." Light should drop down to "not so bright." Now shut off key. Lamp should go clear out. If it does not, and or gets bright, you have a short. Now you can look around and find it. Try disconnecting the alternator, removing fuses, etc
                • Like Like x 2
                • 67Dart273
                  43,401
                  10958
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  5:15 AM
                  You cannot know that. Sometimes wires melt/ weld inside the harness wrapping
                  • Agree Agree x 2
                  • harrisonm
                    harrisonm Well-Known Member
                    2,635
                    2473
                    Jan 16, 2005
                    Topeka, KS
                    Local Time:
                    1:15 PM
                    Why not replace the fuse with an original/correct fusible link?
                    • Like Like x 2
                    • Agree Agree x 1
                    • kursplat
                      2,968
                      1948
                      Aug 24, 2010
                      so cal
                      Local Time:
                      5:15 AM
                      please, for the love of all that is electrical, don't just keep popping fuses in it. you need to crawl under there and start diagnosing this first
                      • Agree Agree x 2
                      • Dana67Dart
                        4,568
                        2788
                        Jul 16, 2017
                        Northern Colorado
                        Local Time:
                        6:15 AM
                        For testing purposes I would get a low amperage fuse like 5 amps. Do not try starting the car but it will give you enough current flow to trouble shoot.
                        Also a fusable link is more like a slow blow fuse, so it is possible that the 30 or 40 amp fuse is just blowing too fast.
                        All that being said you need to get your cars wiring diagram so you can start tracing out your wires
                      • pearljam724
                        380
                        120
                        Aug 29, 2019
                        United States
                        Local Time:
                        8:15 AM
                        I ll post a little video, tomorrow night. Some pictures too.
                        I thought of that too. But, if it consistently blows 40 amp blade fuses. I would think that it would blow a fusible link too ? I think what i’m going to try to do is. Try to mimic the wiring connections on this 73 Dart to my 69 Coronet. They are nearly identical. I’m hoping this will help me pinpoint a problem. A wire has to be incorrectly grounding or touching somewhere, but I can’t see any issues. I’d rather rip a motor completely apart and put it back together than hunting for shit like this. It has to be related to ignition. No problems with accessories, lighting, etc. until the key is returned to off position. It will crank all day, if I want it to. Blows when I turn key off.
                      • j par
                        23,527
                        11988
                        Jul 2, 2014
                        Portland Oregon
                        Local Time:
                        5:15 AM
                        First try not to make wiring into a big thing. it's much much easier than rebuilding a motor and anybody can do the wiring at their own house not have to send things out to an expensive machine shop because we don't have tooling...
                        Simply follow the wire all the way back from where the fuses blowing to where the next connection is... I'm already suspicious if someone added a fuse to this from what I gather to something that already had a fusible link. Probably melting and burning out the fusible link and making a mess... Try not to throw another Band-Aid on it like the previous owner...
                        • Agree Agree x 3
                        • pearljam724
                          380
                          120
                          Aug 29, 2019
                          United States
                          Local Time:
                          8:15 AM
                          I understand, people add in line fuses because fusible links aren’t as easy to find and they tend to be a little more expensive. Plus, it’s easier to replace a fuse than it is a complete fusible link wire. Regardless, I don’t believe the inline fuse is the problem compared to using a fusible link. Something isnt wired correctly or a wire is touching something it shouldn’t be. It has to be on the ignition circuit.
                        • j par
                          23,527
                          11988
                          Jul 2, 2014
                          Portland Oregon
                          Local Time:
                          5:15 AM
                          Yes it's just straight down that wire the keeps blowing the fuse. When you get to the spot it will be fixed...
                          I haven't found fusible links hard to find there right next to the fuses at the parts store...
                        • ragtopfury
                          ragtopfury Well-Known Member
                          2,714
                          2148
                          Jul 14, 2011
                          Manchester, MD
                          Local Time:
                          8:15 AM
                          "I attempt to start the car. It cranks for long as I want, but will not fire"
                          Are you cranking so long that you're overheating the starter and blowing the fuse? Or does it do it if you only crank it for just 1 second as well?
                          If the 1st question is yes - ballast resistor? Ignition control box? Pickup in the dizzy? No fuel?
                          If the second question is yes, eliminate the ignition switch. Disconnect the ignition switch and crank it by jumping the starter relay - see if it blows the fuse from there when you let go. This may be a good place to start (no pun intended)
                          • Like Like x 1
                          • pearljam724
                            380
                            120
                            Aug 29, 2019
                            United States
                            Local Time:
                            8:15 AM
                            No, I can crank it for 2 seconds or 5-6 seconds and it still blows once I turn key off. I’m not over heating starter.
