MOPAROFFICIAL
Oogliboogli
Went and picked up the heads today. They changed the exhaust guides out and for some reason decided to cut the guides for .500 seals.. which is really a laugh since I planned on cutting them myself to .530 and had purchased those seals. So after saying thank you no thank you.. took them home and touched up the "valve job" they did. I'll blend it later. The 75 just kissed the bowl. Going to blend it later. Also unshrouded the exhaust with a couple diff size stones and touched it with a carbide. Measures 3.9388 across. Cylinder Bore is 3.94
