Ben Drinkin
Hey bartender!
Sup MN?Benster !!!!
Sup MN?Benster !!!!
It was pretty breezy here yesterday too and it sounds like it's on it's way to the same today. At least here it doesn't move as much road building material as it does out in the desertHad 10 inches of snow Saturday. 60 with a light breeze today. Supposed to have 40mph winds tomorrow with gusts over 60.. Sounds like a cool place, huh?
Changed out a room at work last month with something like these...I did rewire all the units, myself.. So, saved a bunch there... The difference in lighting in here now, is amazing. I do have three rows of 6 on the ceiling, all on different switches, so I can limit the amount of light, if needed. Was getting pretty dim in here for a while, bulbs going bad, ballasts going bad. Finally made the commitment to change it all, and I'm very happy now...
No....I'm the King of overkill...I filled em all...But, as I mentioned, I have 3 strips of 6 on , 3 switches, so I can turn off. But I like it bright in here...Changed out a room at work last month with something like these...
Metalux 8 ft. Linear White Integrated LED Warehouse Strip Light with 8176 Lumens, 4000K, UNV Voltage-8SL8040 - The Home Depot
Had 4 fixtures. Each had 2 8ft T8s. Smaller, lighter fixture. No bulb. Just a strip of about 500 LEDs. So when it dies, you change the whole fixture. Originally they got some smaller fixtures with 2 strips abought 2ft long and 1.5ft apart. Too dense of a light. Blinding and made a lot of shadows. These spread out the light better and hung directly on the old fixtures positions. The ones we got are brighter and much whiter. They are dimmable, but we don't have that option in use.
Mitch, did you only use half as many bulbs? With the whiter light, it appears that is what the recommendation is.
what all goes into the conversion? new fixtures?I did rewire all the units, myself.. So, saved a bunch there... The difference in lighting in here now, is amazing. I do have three rows of 6 on the ceiling, all on different switches, so I can limit the amount of light, if needed. Was getting pretty dim in here for a while, bulbs going bad, ballasts going bad. Finally made the commitment to change it all, and I'm very happy now...
So you can get a nice tan without going outside. LOLNo....I'm the King of overkill...I filled em all...But, as I mentioned, I have 3 strips of 6 on , 3 switches, so I can turn off. But I like it bright in here...![]()
No.. Originally, 18 yrs ago, they were all big bulb units , with dual oil filled ballasts. Then a buddy gave me a trash can full of T8 bulbs. So I went in each unit and pulled out the dual ballasts and put in electronic ballasts. That lasted for about 8 yrs, until I retrofit to LED....what all goes into the conversion? new fixtures?
Depends on the bulbs. If you get 120v bulbs, just need power to the ends. Rip out the old ballasts and pop in the bulbs. With fixtures already in ceiling that's the easiest. For free hanging fixtures, probably just as well to just swap fixtures. One big advantage for our use at work is it eliminates the wide side reflectors that collect a lot of dust.what all goes into the conversion? new fixtures?
On the single pin 8 footers, just cut ballast out and wire everything on one end to your hot wire wnd the other end to the neutral.what all goes into the conversion? new fixtures?
Playtime! Too bad the Scout isn't driveable!Had 10 inches of snow Saturday. 60 with a light breeze today. Supposed to have 40mph winds tomorrow with gusts over 60.. Sounds like a cool place, huh?
Just be aware the old ballasts and bulbs are hazardous waste and you may need to pay to get rid of them.awesome, I've been trying to figure out the lighting for the garage im building next spring. I can get a bunch of those old energy hog industrial light fixtures for cheap.
I had all florescent lighting in my tool truck only 12 volt stuff which is even more expensive to fix. I wires in some peel and stick LED strips under the shelves. .8 of an amp current draw per 8' strip. I was able to combine 3 circuits together on 1 breaker. Way easier to turn the lights on when and super bright when it's 0° out.I did rewire all the units, myself.. So, saved a bunch there... The difference in lighting in here now, is amazing. I do have three rows of 6 on the ceiling, all on different switches, so I can limit the amount of light, if needed. Was getting pretty dim in here for a while, bulbs going bad, ballasts going bad. Finally made the commitment to change it all, and I'm very happy now...
I guess that rules out throwing them in the dumpster and throwing a rock in there after to disintegrate themJust be aware the old ballasts and bulbs are hazardous waste and you may need to pay to get rid of them.
niceJust be aware the old ballasts and bulbs are hazardous waste and you may need to pay to get rid of them.
I guess that rules out throwing them in the dumpster and throwing a rock in there after to disintegrate them![]()
What's that Mike?Just another brain fart on my part
