about same here. Our expected 'coating' of snow has passed one inch and still going.My clock just changed after I read your post and checked our temp... It's now 15° F here....
That must be the 1/2"-drive version then. Here is the 3/8"-drive version, from Halifax Homemade Tool Co.They make cake in both 1/2" and 3/8" drive...
How many tenths? That probably doesn't even register on the white knuckle scale.Why is the spec for setting the steering box tension in tenths of an inch-pound? Who in the world makes a 10ths-inch-pound torque wrench?
my grandfather has one from when he built engines for Cummins back in the 60s, it reads in tenths of an inch pound. Why? I don't know but its there.Why is the spec for setting the steering box tension in tenths of an inch-pound? Who in the world makes a 10ths-inch-pound torque wrench?
I couldn't find one one for reasonable cost considering how little it was going to be used.How many tenths? That probably doesn't even register on the white knuckle scale.
Have at least two here now. Funny how some tools just show up over time. I use them a few times a year to help with molding profiles (woodwork; trim, sash, railings, etc).Here ya go TMM, picture of an obscure tool I used today for melding fabricated dash to existing contours. Thing sits in your box for years unused but sure was handy today.
Out.No Jalepenos?
We (MAC Tools) used to have 2 catalog pages full of distributor wrenches. Other than the universal one, I haven't sold one for decades. They haven't been available for that long as well. LOLIt must be Friday-Fabricated-Seldom-Used-Tool Day. The mystery tool from Halifax Homemade, that I put on here earlier, is for getting at the distributor hold-down bolt when you're timing a car that has the distributor up against the firewall.
Agreed. A lot of torque to yield nowdays. You need to be precise now days for sure.So just thinking out loud as I need to drop oil pan again on modern Hemi and swap some crank bolts for PU tube support. The need to adhere to actual torque spec guide lines vs calibrated elbow is becoming more important in my humble opinion.
Again in my opinion, but in a large part as a result of the utilization of more and more modern materials. The materials used, are getting stronger and stronger yet thinner and lighter (more flex) thus resulting in a more pronounced need to adhere to the OEM guidelines on torque spec values on modern components.
Case in point the Milodon oil pans for conversions with Gen 3. There are about a million postings explains how bad they leak. I can only speak for the one I have but I just have not found that to be true for me. I follow the torque spec guidelines and wa la no leaks.
Please note the disclaimer I am not a actual mechanic, more of a parts changer if you will. Stay warm guys!
I tell you what. If the radar looks good about 2 this afternoon it's off to KCRP for Late Models I go. Course getting home may be an issue. Wouldn't be the first time I crossed a flooded section of that road.
No doubt it is more critical on the newer stuff. But, even in by old Plymouth FSM I have never seen reference to a 'smidge' or a 'c*** hair'So just thinking out loud as I need to drop oil pan again on modern Hemi and swap some crank bolts for PU tube support. The need to adhere to actual torque spec guide lines vs calibrated elbow is becoming more important in my humble opinion.
Actually, one of the things that I picked up is a portable dish washer just for this purpose.
I tell you what. .
