Man those role players at Gettysburg prob were dying in the uniforms yesterday! Bet they are glad it is over.
Aren't they doing it again today? I have a couple guys I work with going down today. There is something going onMan those role players at Gettysburg prob were dying in the uniforms yesterday! Bet they are glad it is over.
You get all the funToday i get to tear down a street demon.
Carb is gummed up, they supplied a rebuild kit, has everything,idle screws float setting screws.
Then install and dial it.
Think today is the last one started Wednesday I believe. And we ***** about the heat at Carlisle!Aren't they doing it again today? I have a couple guys I work with going down today. There is something going on
I rebuild Holleys all the time.....I used to be the go to guy when i was around 20.. All my buddies brought em to me......Today i get to tear down a street demon.
We used to rebuild them in the back room of the parts store. We had all the goods in stock.I rebuild Holleys all the time.....I used to be the go to guy when i was around 20.. All my buddies brought em to me......
Bad ground.Got a question for the Coffee Crew, the wife’s 2001 Ram 1500 4x4 5.9 Magnum periodically when outside temps get hot and she turns on a/c the dash warning lights come on and all gauges including speedo stop working. Truck runs fine and the air works I believe, not for sure on that because she has shut off the air immediately each time. No working gauges and warning lights on freak her out. (Not a bad thing in my book)
Any thoughts?
A hunting I will go!Grou
Bad ground.
I have cleaned them, replaced power valves and the like.I rebuild Holleys all the time.....I used to be the go to guy when i was around 20.. All my buddies brought em to me......
It's possessed! Did you see my post last night about the wife '09 Journey? Horn goes off when nobody is near it..lolGot a question for the Coffee Crew, the wife’s 2001 Ram 1500 4x4 5.9 Magnum periodically when outside temps get hot and she turns on a/c the dash warning lights come on and all gauges including speedo stop working. Truck runs fine and the air works I believe, not for sure on that because she has shut off the air immediately each time. No working gauges and warning lights on freak her out. (Not a bad thing in my book)
Any thoughts?
Hey, one other thing, did you take it in for the recall yet? On the airbags and steering columnIt's possessed! Did you see my post last night about the wife '09 Journey? Horn goes off when nobody is near it..lol
yesHey, one other thing, did you take it in for the recall yet? On the airbags and steering column
That's why I said in original post, I doubt its a worn out horn switch. Pretty sure that is replaced as part of the air bag. Plus, I can bump the steering wheel every which way and it doesn't beep.Hey, one other thing, did you take it in for the recall yet? On the airbags and steering column
HmmmThat's why I said in original post, I doubt its a worn out horn switch. Pretty sure that is replaced as part of the air bag. Plus, I can bump the steering wheel every which way and it doesn't beep.
I know the main battery ground attachment point is good. Just had that apart. Cleaned and tightened. I will have to look for other grounding issues. I have the horn fuses out, so will be interesting to see if any other issues pop up. I did have one time recently where it didn't start on first try - which is indicative of the fuel pump relay failing.Hmmm
I’m wondering if something has come loose in the column?I know the main battery ground attachment point is good. Just had that apart. Cleaned and tightened. I will have to look for other grounding issues. I have the horn fuses out, so will be interesting to see if any other issues pop up. I did have one time recently where it didn't start on first try - which is indicative of the fuel pump relay failing.
I think if it was it would show up when I bump it around. And as Frank said about clock spring.I’m wondering if something has come loose in the column?
How’s it shaking
