All he has to do to keep it nice and cool is just pull them dang pesky things that go to the defective spark plugs!!! And quiet as well........It's them damned fenderwell headers!
That'l do it!!I think I found my off idle stumble. The accelerator pump wasn't doing anything. When I attempted to adjust the arm, it was at the bottom of the stroke already. No spring pressure. Pulled it apart and found nothing put of the ordinary. Diaphragm wasn't torn and spring was good. Not sure, but the replacement from another Holley carb has the spring pressure as it should. Need to clean filter and try tomorrow. With no pump at all, it would explain the lean spot. Also need to readjust the front brakes. Then try driving again. Bit by bit...
Wonder if there's a check ball in the well?That'l do it!!
What ya gettin'?Well Amazon has the tires I need for 55 a pop, el cheapos but still will work for what I need
Should be, or an orange flapper.....Wonder if there's a check ball in the well?
Did that shizzit months ago, Me thinks thee behind the curve....Cut grass for a couple hours. Yard starting to look better. Have to pull out some saplings growing around the house.
And trim more trees.
285/35/18sWhat ya gettin'?
285/35/18s
The dart.I'm afraid to ask what you're going to put those on.
What brand? At 55 I could practice a little mock up myself..Well Amazon has the tires I need for 55 a pop, el cheapos but still will work for what I need
LionhartWhat brand? At 55 I could practice a little mock up myself..
Steppin up? From mockery to mocking up?What brand? At 55 I could practice a little mock up myself..
One must grow at some point!Steppin up? From mockery to mocking up?
Why?One must grow at some point!
If only to avoid stagnation.. It's not glamorous, but it is necessary!Why?
Ok, if you insist.....If only to avoid stagnation.. It's not glamorous, but it is necessary!
