Will add, wasnt me the other 2 times.I never use impact,just dont trust myself. Seeing as the preload was gone before i touched it and this being the 3rd round i want to be close. Sneak up on it so to speak.
N158 is the end corner spot.What number is the corner at the cross aisle?
Ya Joel has done so many. He tightens, feels it for play and drag and gives it another blip if needed. He's the go to guy when the other dealers can't get a noise out.I never use impact,just dont trust myself. Seeing as the preload was gone before i touched it and this being the 3rd round i want to be close. Sneak up on it so to speak.
What are you selling?
Tim is bringing his travel trailer so everybody has a place to stay.Nothing...
The rear end on my 2017 Ford is noisy as hell. Whines. Dealer "it's normal" while under warranty. It's not....Ya Joel has done so many. He tightens, feels it for play and drag and gives it another blip if needed. He's the go to guy when the other dealers can't get a noise out.
Well, was considering bringing my 5'ER.Tim is bringing his travel trailer so everybody has a place to stay.
Might be a problem......Might not.....Got to think on that one. Don't need a bunch of friends/drunks pissing all over the floor!!!Tim is bringing his travel trailer so everybody has a place to stay.
That's what behind Mitch's trailer is for. LOLMight be a problem......Might not.....Got to think on that one. Don't need a bunch of friends/drunks pissing all over the floor!!!
win some, lose some.Could not get the end spots, rented already. Bummer.....
Here for example. It seems a sandy epoxy layer was added into the case first followed by a rubber RTV type layer to finish the encasement of the board. Not sure it was a good choice since silica based substrate acts as an insulator rather than dissapating heat effectively. The local temps around the board components must have gotten pretty high. No wonder it burned out.
Seems like they chose manufacturability ease over longevity. This approach makes manufacturing easy...but life span is sacrificed. They would have done better with a quality heat sink material to conduct the heat to the case. Instead, the RTV type material is encasing the upper part of the components like a silicone oven mitt and the layer under it can’t extract the heat well anyway.
Heck, I might not even go next year. A little expensive....
I like liverwurst. Guessing about same thing...
View attachment 1715415472 I was fine with winter until about 10 years ago,our first cruise. I had no idea what i was missing. Then a few winters having to work outside finished it off.
winter whiner? You dam right, i earned the Privilege to complain. Couple rounds of frostbite here and there and i have had about enough.
Diff is pretty much assembled. Backlash seems good, im not measuring,but experience tells me its close.
painted cover and waiting for it to flash off. Always paint my covers,it only takes a little time and it looks better.
Just got a parking spot close N183!Heck, I might not even go next year. A little expensive....
Housing and cover may be aluminnium..some were.I am surprised the rear axle on my 04 Grand Marquis is totally unpainted, both the cover and the rest. As you say, it looks so much better painted. And it last longer in that nasty salt they use in that nasty winter
Bill
