Stop in for a cup of coffee
Timing cover gaskets/seal done.
Would like to have a timing set for it but not readily available.
Heres a kick in the ***, have to drop oil pan to get 1 timing cover bolt out.
Second time i dropped the pan. Just as well, it had a bunch more gunk in it. Engine should be pretty clean now. And i discovered pcv was on wrong fitting on carb. Maybe it will run better? It was real rich before. Adding a controlled vacuum leak may lean it some.
Was going to cook a nice Roast in the crock pot today, but time got away from me. Found out I should cook it for 8 hrs on low. So....I guess it is more Jambalaya for dinner tonight....
Subway tonight. Fargo seems to run different with pcv on proper port, need to change idle mixture tomorrow. And almost no vapours out vent cap.
At least you had a back up plan!
I better get downstairs myself. Soup leftovers is fine but need to make some stew too
I just had a New York Strip steak cooked in the wood stove with baked potato
Just some vegetable lasagna here tonight...
No more wake ups but that cold front moving through our flight area as well as where the airport is may slow stuff down tomorrow.
Seems some of us were too helpful and drove a long time member to quit.
Maybe if he started with a different screen name he'ld have had a better chance.
Never good when you defeat yourself before you even start...
We get to go give blood for TB tests and I have a physical for a medical cert. renewal. All before leaving Houma, LA to head home.
Thread is Performance Timing
Halifaxhops dragged me into it.
Then he disapeared. LOL
I think what's going on is Dazed has been all over the internet reading different things and mixing them up.
At least you didn’t get extended. Unlike others I know given the current world affairs. Glad you’re gonna get home though. Safe travels
