That's my gut feeling about this too.They aren't hard to pull if they need to be repaired. If it works don't mess with it...JMO.
Some caps had oil in them. Don't know if this one does.
Light bulb still works after 50 years and how many thousand miles!They aren't hard to pull if they need to be repaired. If it works don't mess with it...JMO.
Now, I did not say it will explode, I said that is a common way they fail. Come on Trump, Or Matt!!You can use any 50MF Cap with at least 3volt range. As long as the form factor fits...Del thinks its bestest to replace. Tim thinks it will explode, and Kieth thinks its leaked.
Radio cleaning and pre-emptive cap. repair?
Radio still works. I'm going to try to get a better light on it today or tommorrow.
Maybe just insulation over the metal shell?
Just teasing! LOLNow, I did not say it will explode, I said that is a common way they fail. Come on Trump, Or Matt!!You can use any 50MF Cap with at least 3volt range. As long as the form factor fits...
More then likely soldered...Just teasing! LOL
Ya. Looks like new ones can be made to fit if needed. Would need to first confirm its soldered to the board. Might be snap in?
And I guess my big takeaway was not to try to find an exact replacementDid find this discussion. Same as you and Del have said about using something close in spec will be fine.
Antique Radio Forums • View topic - Electrolytic source for transistor radios
I would either replace it or do nothing. Covering it will only trap heat and possibly make it worse. My point was that the crack allows 'gas' to leak out vs blow it apart.Del thinks its bestest to replace. Tim thinks it will explode, and Kieth thinks its leaked.
Same, yuck... Looks like this cold dropping in is going to push us right to the May 15 'frost free/safe planting' day. Friday night supposed to be the worst -temp keeps showing 1-2 degrees colder each day as we get closer - is now showing 30F.Cold and rain here today!
I have been monitoring the situation. At this point, they are offering 100 percent future cruise credit. I want them to cancel the cruise So I get my money back or 150 percent credit....Will wait til the last day to cancel myself, 48 hour cancellation window.Uht oh... @Mopar Tim - Is your big cruise with Norwegian? Now saying this could put them out of business...
That's assuming they have something to give back...Is it insured, like if they fold completely?I have been monitoring the situation. At this point, they are offering 100 percent future cruise credit. I want them to cancel the cruise So I get my money back or 150 percent credit....Will wait til the last day to cancel myself, 48 hour cancellation window.
unfortunately the bung for this tank is 3/4 NPT. so I'd have to reduce it, wouldn't that defeat the purpose of the 1.5 inch pipe?Use LARGE diameter piping to connect them....1 1/2 at least..IMO
im still waiting for our money back for our cancelled trip as well. Travel insurance company hasn't paid it yet, been 2 months already. I get the feeling this is gonna put them out of business too. The legal question is, will the NAIC have to bail them out firstI have been monitoring the situation. At this point, they are offering 100 percent future cruise credit. I want them to cancel the cruise So I get my money back or 150 percent credit....Will wait til the last day to cancel myself, 48 hour cancellation window.
If they go BK, it will raise concern's...That's assuming they have something to give back...Is it insured, like if they fold completely?
Not too bad. It would get hot there, when ever you push air thru a small opening, then into a bigger pipe, it creates heat. Because you are compressing it...unfortunately the bung for this tank is 3/4 NPT. so I'd have to reduce it, wouldn't that defeat the purpose of the 1.5 inch pipe?
hmm so the outlet from my little tank is 3/4 npt as well, so with that in mind, think itd be better to just run a straight 3/4 npt to the bigger tank? Seems to me that going from 3/4 to 1.5 back to 3/4 would be kind of pointless?Not too bad. It would get hot there, when ever you push air thru a small opening, then into a bigger pipe, it creates heat. Because you are compressing it...
i get that, but id be going from little pipe, to big pipe for like 2 feet, then back to little pipe, then to tank B?The bigger pipe flows more air...less restriction...The storage tank should have a large intake fitting....It would be better. I have seen 1 inch galvanized used for similar setup that seem to work.
That is better then small connection pipe. Do not use PVC pipe. It will get hot...that connection...i get that, but id be going from little pipe, to big pipe for like 2 feet, then back to little pipe, then to tank B?
I think there is some gain in still going bigger on the pipe. Every elbow is a restriction, but we don't upsize at the elbows to keep it all even...So, maybe 1" to reduce that factor. On the other hand, I would ask what you are doing with it. If you are not using that much air it might not matter. A couple tools on 3/8 air hoses are going to be fine on a 3/4 feed. Of course that could make a case for whether you need extra storage at all. Will the compressor keep up with whatever you are doing? The extra storage is just allowing you to build air in the off time when tools are not drawing it as fast as compressor pumps it out. Also, watch the MAWP ratings on tanks!hmm so the outlet from my little tank is 3/4 npt as well, so with that in mind, think itd be better to just run a straight 3/4 npt to the bigger tank? Seems to me that going from 3/4 to 1.5 back to 3/4 would be kind of pointless?
MAWP?I think there is some gain in still going bigger on the pipe. Every elbow is a restriction, but we don't upsize at the elbows to keep it all even...So, maybe 1" to reduce that factor. On the other hand, I would ask what you are doing with it. If you are not using that much air it might not matter. A couple tools on 3/8 air hoses are going to be fine on a 3/4 feed. Of course that could make a case for whether you need extra storage at all. Will the compressor keep up with whatever you are doing? The extra storage is just allowing you to build air in the off time when tools are not drawing it as fast as compressor pumps it out. Also, watch the MAWP ratings on tanks!
I have some air pipe left over from when I plumbed the farm shop with air all around it.That is better then small connection pipe. Do not use PVC pipe. It will get hot...that connection...
MAWP is the maximum pressure at which the vessel or equipment is allowed to function at a specific temperature. 3. Design pressure is the condition of coincident temperature and pressure that is expected in a normal condition.MAWP?
gotcha, this tank is rated for 175. but my little one is rated for 150 and the shut off trips about 140 so I should be fine.MAWP is the maximum pressure at which the vessel or equipment is allowed to function at a specific temperature. 3. Design pressure is the condition of coincident temperature and pressure that is expected in a normal condition.
Difference Between MAWP and Design Pressure | Difference Between
