Does air have lumps?I just had a nice long Fart.....I needed that.........
That **** will buff out
You was doin just fine til the wheel fell off!
It was on our new(used) grain auger. 253 miles hauling this *****You was doin just fine til the wheel fell off!
“Ya picked a fine time to leave me loose wheel”
108 here..................CRAZY!!!!!!!!!!!!!Boy Howdy! I'll say the NWS missed on the predicted high! 101° out there .
62 here108 here..................CRAZY!!!!!!!!!!!!!
Gettin it doneBunch of sheet metal hanging! View attachment 1715604717View attachment 1715604718
Yeah. Inner bearing ate itself after 207 miles, less than 20 miles from homeA problem?
You should do like I do and grease the bearings before a trip. Especially a long trip.....Take the time and not have problems....Yeah. Inner bearing ate itself after 207 miles, less than 20 miles from home
We did. That’s the annoying thing. We even swapped brand new tires onto the rims and installed new lug studs and nutsYou should do like I do and grease the bearings before a trip. Especially a long trip.....Take the time and not have problems....
Should of taken a pic but I didn’t. Bearing cone was the only thing left. The rollers and stuff all ate themselves. But what is striking is normally when this happens, there’s heat scoring, spindle had none. Nor did the inside of the bearing race.You should do like I do and grease the bearings before a trip. Especially a long trip.....Take the time and not have problems....
And... A Burp........
Then bearing design was not up to long travel......Should of taken a pic but I didn’t. Bearing cone was the only thing left. The rollers and stuff all ate themselves. But what is striking is normally when this happens, there’s heat scoring, spindle had none. Nor did the inside of the bearing race.
I don’t know. The bearing used when we cross referenced the part number on it at the store came back to a ford truck front hub bearing.Then bearing design was not up to long travel......
