Good Morning Mopar Madmen and Women !!!!
Two tubes for wires, maybe bullet terminals. 70’s mopar alts.PM or call me, Need more info. like make model of alt and application? Have a ton of BWD stuff that is non Mopar I am going through, definitely aloof starter and alt parts. Hey what connections on that brake switch does it has like two tubes for wires?. Also that starter switch is for the pedal, it has adjustable height.
I'm burning splits, mine would be more like a funnel to not damage the window frame. but would have a lot of work/rearranging to move the workbench i built into the corner. Maybe I could do some sort of slide board right over the bench...Used 2 14 foot 2x4’s and a 18” wide strip of plywood.
Bingo!I'm burning splits, mine would be more like a funnel to not damage the window frame. but would have a lot of work/rearranging to move the workbench i built into the corner. Maybe I could do some sort of slide board right over the bench...
Any idea what on the alts? I have a lot. I do have a choke timer somewhere from my 74 slant used that work?Two tubes for wires, maybe bullet terminals. 70’s mopar alts.
And electric choke control.
LOL, easier said than doneBingo!
Push it into a pile with your tractor and light it.LOL I should have a tear down party here instead of a lift day to get rid of half that chicken coop, bring your beaters we can drive through it to break it down!
Seriously was thinking about that but has lines overhead.Push it into a pile with your tractor and light it.
Power lines? They don’t really need all that insulation on them anyway...Seriously was thinking about that but has lines overhead.
LOTS of boards in that one half packed with lumber. To bad it has powder post beetles in a lot of it!I may even haul the boards away...I love to build big fires!
Me too. Sounds like funI'll come I love tearing things apart
If any is good it’s worth saving. Lumber is frickin expensive right now! I’m re-using everything I can on this shed job.LOTS of boards in that one half packed with lumber. To bad it has powder post beetles in a lot of it!
