Stop in for a cup of coffee
Get a wiring diagram. Before you start understand how it works. Follow wires on diagram till you get it.....study it.
I have one actually. I’m working in Solidworks redrawing it into color so it’s much easier to read
It's Flamin' Friday!
Good morning :D
Chris. Good grounds are important. Try to ground circuits together. Not splice grounds together. Run ground wires to a central location and ground to body together.
AND all black wires should be ground. ONLY use black for ground. If you see a black wire, you know it is a ground...
Yep, coffee break time here too.
It definitely is now. Holy humidity Batman! I’m soaked.
Reseting all the blocking under this thing. Just wanted to move this one a little closer to center. F’n root - Sawzall time! Not sure it even needs it, but the extra support is part of why the shed didn’t collapse years ago…
Took pan back off. I think I see why it was leaking. But everyone will agree the rear of the small block is the most problematic for oil leaks. So WTF did some engineer think it was a good idea to have the smallest sealing area of the entire pan at the rear?
The black area is the sealing area....
