Unconventional
So I could not get 904 to upshift soon enough. Bought Hollie adaptor. Hopes this fixes issue
Any GV improvements?
They arent that difficult, if you have an oem manual to refer to.This is my first time playing with a carter bbd
All my manuals are on a usb I forgot on the boat in Mexico. Currently charging battery and adding grounds.They arent that difficult, if you have an oem manual to refer to.
Have not got there yet. I am still working out getting the 904 to up shift correctly.Any GV improvements?
So it's not a Manuel only shift .Have not got there yet. I am still working out getting the 904 to up shift correctly.
Does it shift a little early? Looks like it would.
No it shifts late!!!! Going to drop the pan on the trans and see what the adjustment is on the kickdown. Throttle pressure linkage...Does it shift a little early? Looks like it would.
If I cannot get this worked out, a manual valve body is going in. I am tired of this crap....So it's not a Manuel only shift .
Your kickdown lever on the transmission and the throttle should both be at maximum at wide open throttle.No it shifts late!!!! Going to drop the pan on the trans and see what the adjustment is on the kickdown. Throttle pressure linkage...
LOL it is......Still more road testing in my future.....I am beginning to think the throttle pressure lever is miss adjusted....Your kickdown lever on the transmission and the throttle should both be at maximum at wide open throttle.
Seems simple enough!!!Your kickdown lever on the transmission and the throttle should both be at maximum at wide open throttle.
WAY to far down the road for that!!!Just put in a 4spd and call it a day
I get it just poking fun.WAY to far down the road for that!!!
I know......I will say, it runs real well!!!! And the 3:23 gears make a big difference on RPM's Now, if it would just shift correctly....I get it just poking fun.
Not to bad. Looking forward to Thursday.Hey Ray... how's tricks today?
Wish I was there with you guys.....Have fun....Not to bad. Looking forward to Thursday.
Wish you were too. Not to late to fly out.Wish I was there with you guys.....Have fun....
I told him to put a t56 in it....(itd been cheaper)Just put in a 4spd and call it a day
Nah, sell the trans and gear vendor, clear 5k easy. Get ya a t56 for 2500 or less, cut a hole, installed clutch and bellhousing for another 3-5 hundred and come out 2k aheadWAY to far down the road for that!!!
You see where I posted that your Dart and mine is in the same class, At Carlisle?I told him to put a t56 in it....(itd been cheaper)
