They yours Willie?
Been there. Getting smarter in my old age though. I know my limitations. "make the call, write the check" is my new motto!I too am sometimes option 4 lol!
They yours Willie?
A Dakota Express? Never heard of one.
Popular sticker package in the 90s, wasn’t a dealer or factory optionA Dakota Express? Never heard of one.
I kind of like the Magnum's. The front ends look like Cords from the last century.1978 Dodge Magnum XE - cars & trucks - by owner - vehicle automotive... (craigslist.org)
I guess today is the day for me to see some cars/trucks that I didn't know existed!
Figuring out, plexiglass is a pita to cut
You score it like glass only more times on the score line.Figuring out, plexiglass is a pita to cut
Other than Hoppy helping me with ignition, (he makes house calls if you are 'local') I only had one of those on the Duster. Couldn't get an upper ball joint out. Took control arm up to the garage. Brock put it in the big *** vise and zipped it out with an impact. Think he charged me $20...Can't like that..
Because there's a probability that I'm eventually "That guy"
Jig saw works good. We do a lot of Lexan guards at work. Datails we use band or jig, but got a special plastic blade for the table saw that does a good job. You can use a regular blade, but more teeth is preferred. Big teeth or feed too fast and will chatter or shatter. Too slow and it can melt on the blade...Are you using a band saw or jig?
JIG saw, 1/8th thick smoke grey. It’s fracturing it even with a fine diamond bladeAre you using a band saw or jig?
For straight cuts, circular saw with fine tooth blade. Put blade on backwards.Jig saw works good. We do a lot of Lexan guards at work. Datails we use band or jig, but got a special plastic blade for the table saw that does a good job. You can use a regular blade, but more teeth is preferred. Big teeth or feed too fast and will chatter or shatter. Too slow and it can melt on the blade...
