It may be I’m just feed too fast as pointed out above, I’ll try again after wife gets back home, I’m on daddy day care dutyBummer, if blade speed doesn't fix that I dunno. Good luck!
PUT THE BLADE ON BackwardsIt may be I’m just feed too fast as pointed out above, I’ll try again after wife gets back home, I’m on daddy day care duty
JIG saw, 1/8th thick smoke grey. It’s fracturing it even with a fine diamond blade
Just a masonary blade. Says for glass titles. Only thing I could find locallyIs the blade FOR plexiglass, if not it may have teeth flared that would cause cracks.
"soft wood" that happens a lot as you get older. They make little blue pills for that!PUT THE BLADE ON Backwards
Did that actually,Lay down wide Masking tape and put your cut line on it. Cut the plastic with a fine tooth blade and pull the tape off when done
May go get a glass cutter and try that. I just need 3, 4.5 inch diameter circles.
Then too coarse of blade being pushed too fast. I don't know. I use my angle grinder and metal cutting blade then smooth the edges with a file when done.Did that actually,
Gee thanks mike. Now there are some serious armchairs talking there.
Crank, crank, tries to start as the key is released. | For B Bodies Only Classic Mopar Forum
This one was a beautYou nailed it the line lock neutral only saftey switch is the issue. I did that one post and am done.
We had to call a guy known as 'The Hat' to remove a upper ball joint in my '75 Valiant. He was a mobile service guy. That was in Newark NJ - seems like a lifetime ago.Other than Hoppy helping me with ignition, (he makes house calls if you are 'local') I only had one of those on the Duster. Couldn't get an upper ball joint out. Took control arm up to the garage. Brock put it in the big *** vise and zipped it out with an impact. Think he charged me $20...
Love it!
Over 3” already with many hours to go!Good AM all you snow bunnies!!!
You need to post something with the word 'vacuum' in it.I hope Bew....chimes in
Speed! Fun!View attachment 1715886864
And there was a time in my life when all I wanted to do was move to the Sierras and ski my brains out all winter when construction in the flatlands was taking the winter off for the rain .
was I thinking?
A Dakota Express? Never heard of one.
A guy I know who lives not far from me had three Little Reds, one being Dakota, bought them all new and lost them all plus other Mopars in a fire.
