Stop in for a cup of coffee
A great paint for that stuff is appliance paint, it is some sort of epoxy and is really durable.
Speaking of epoxy, any suggestions to use to glue plexiglass to aluminum? Something that won’t melt under extreme heat or crack under extreme cold? And can with stand vibrations
Both difficult to glue. Superglue maybe. Will hold, but not a true bond that I would trust under vibration etc
@toolmanmike Deere sure didn’t take long did it
I may find a better way than epoxy.
Most epoxies do not stick to plastic. JB Weld makes one that will. BUT it's not going to grab the aluminum very well. Maybe if roughed up. Almost any glue peals off aluminum. What is it for? There are some very aggressive double side tapes that will hold if not much weight and enough surface area.
making custom gauge bezel
OK. You could have led in with that... If you can do at least a 1/4 inch lap and its flat -superglue gel or 3m molding tape should work.
Can't you clamp it in mechanically somehow? Would be best even if its just a few points. Do that and the tape or glue and never have to think about it.
