Man you have ugly help. Hope you upgrade them!
Thats about a good a car as you can get. Not a drop of rust on it at all.Besides that, my car is complete. Have everything
Note Ben's Uranus shirt. I can't read the small print.Man you have ugly help. Hope you upgrade them!
Yes. Need to practice though. Hope you can tack it then remove pipe to fully weld it. Clean it if its old pipeAnother hot one today... but still getting into the low 60s at night so that makes it not so bad.
Rear flex brake line arrived yesterday from inline. Get that wrapped today and pull the Booster out hopefully.
Need to figure out the exhaust. .030 solid wire enough to weld pipe?
Where are they?Any recommendations for welding this? Didn't realize that the "press studs" were slid into plastic slots. I did buy a couple 1/4 20 bolts thinking I was going to tack them in, now dunno.
Everything from the header back to the rear axle is out right nowYes. Need to practice though. Hope you can tack it then remove pipe to fully weld it. Clean it if its old pipe
That would make a killer salt water bay fishing boat.
Where are they?
Into the fiberglass on the heaterbox itself?
Weld bolt to a strip of sheet metal, then pop rivet to heater box.There's two on the right side edge, one twisted, one spun in half. I really made things harder for myself on this one.
Or just wel a tab to the bolt and epoxy it in.
