Is it even Monday yet out there?
Morning
How far is it to Chicago!
Looks clean enough to eat off of. Lol
You be up early for such a late night wrenching?Is it even Monday yet out there?
Morning
Yeah. Just debating on the placement and if there is actually much benefit...
I'm installing the new lines and getting them back to original routing
Thanks.. yeah I can't go 3. I've only got about 3/4" clearance on the OEM radiator now. Aluminum is probably the way to go in order to increase efficiency
You need to put it where air can go through the fins... Most people put them in front of the radiator or condenser...
Got rifle sorted out from yesterday match, OAL issue with ammunition. Had to take lever completely out of the receiver to clear it. Going to try and get windows installed today in big house, and add a 110 receptacle to a finished wall. Plus oversee garage door install by overhead door crew. We are trying to get big house in the dry before Xmas. Other than that should be a easy day.Yeah.... I had a target completion point yesterday... it happened to take until today to get there. Hadn't planned on the complete rework but it was good to get it done.
How's things in AR?
Actually I hold a
Minor in American History and Geology
Plus if I can get someone else to pay for it, why not?
Yep. But in this case, if I could learn something that will help me with my passion AND get someone else to pay for it, win win
So what do you do then? Not sure what you're talking about (it's me). A bearing in a cross member?Morning!
-3. Not bad at all. Will go above freezing today, for the next few days. Edge is back in shop,ball joint and drive shaft. Nice,center support bearing is not good, failed safety inspection and isnt replaceable.
About 22 miles from my house to downtown...
Less for the outskirts...
Thanks Karl. Yeah I'm thinking of eventuality putting one behind the grill. I did a bunch of reading... the external cooler should be AFTER the fluid leaves the radiator tank (??) and not pre- cool.
Ever heard that?
Driveshaft has a u-joint 1/2 way.supported by a hanger and a bearing.welded together in factory. For years they were replaceable. So,$900 later(plus labour) he gets a new driveshaft.So what do you do then? Not sure what you're talking about (it's me). A bearing in a cross member?
