The one I pictured is a little messy but it get's the job done. Screw a zerk into the end and you can snap it onto your grease gun coupler.
this is the tip, I heard the lock and lube stuff isn't that good tho. I know I don't have access like shown here, need a right angle or something to come in not parallel to mower deck
That's what I'm thinking about trying, thanks.
I have one around here and use it occasionally. I try to replace the zerks with 90° ones if I can. Sometimes there's no room for them.That's what I'm thinking about trying, thanks.
Never used a slide on type like that. The regular 90s work OK. But if it’s your own equipment, I would change th fitting to a 45 or 90. The it’s greasable with a straight tip.The one I pictured is a little messy but it get's the job done. Screw a zerk into the end and you can snap it onto your grease gun coupler.
None of mine have a cordI would like a cordless grease gun. I have a pistol grip one but the cordless are so much easier with my 67 year old grip.
cordless electricNone of mine have a cord
Roller coaster here. It's supposed to be 70 Thursday and down in the low 50's over the weekend.View attachment 1716082115Morning . Sure wish it would warm up !
Not bad for Ontario. Is the ice out on the lakes yet? Probably not until May.View attachment 1716082141About the same here!
Not good , sucks getting old!Hey kids
Full day ahead... Meh...
Shoulder giving me fits. Slept on it and it's unhappy
I'm not sure why there's zerks on these spindles because I think the bearings might be sealed as well. One thing I know is I've had several spindles fail in 4 years, maybe not that high of a casualty considering all the rocks I've hit so yeah, all the failures weren't the bearings, cracked housings etc.I don't think my spindles even have zerks. Especially for home use, a lot of stuff really doesn't need it. Something else goes before the grease. Over years of doing maintenance, I couldn't tell you how many times I have taken something apart to find out it has sealed bearings -after greasing it for years.
I'm on the river , we had ice only a couple of times . Been clear for a while.Not bad for Ontario. Is the ice out on the lakes yet? Probably not until May.
Welcome to my world.Hey kids
Always bugs me that they do that. I think forcing grease on a sealed bearing adds to the chance of it spinning in the housing. Which is how my previous set of spindles failed. I don't recall if the bearings were open or not.I'm not sure why there's zerks on these spindles because I think the bearings might be sealed as well. One thing I know is I've had several spindles fail in 4 years, maybe not that high of a casualty considering all the rocks I've hit so yeah, all the failures weren't the bearings, cracked housings etc.
I'd like to think if the engineers put a zerk there it served a purpose, then again I see where they put the fittings so there you goAlways bugs me that they do that. I think forcing grease on a sealed bearing adds to the chance of it spinning in the housing. Which is how my previous set of spindles failed. I don't recall if the bearings were open or not.
Life's to short to drink decaff.What? Every one drinking decaff today?
Good point, transmission not serviceable on my lawn tractor either, gotta believe you put 300 or more hours on one it couldn't do anything but extend the life of it. I'm looking for a good siphon for my daughters El Camino, so gas and 20 gallons of it. She's not driving it and it's sludging up, she put premium in it as always but not ethanol free, her Holley doesn't like it!I think today I need to get the rider and push mower out and get them serviced for the season. I sure would like to change the hydrostat oil. I'll have to suck it out. it's non serviceable. I have one of these. It works great. I use it to change oil in the push mower as well. A lot more fun than trying to get underneath it to get to the drain plug over a drain pan. Push mowers are a pain to change oil in.
Readily available. I have one, I use occasionally....
Nope. Just a green painted 2x4 with a bolt hole in it. It’s a safety for a chain drive on a grinder.A wood bearing? Yep. I could see it.
