Stop in for a cup of coffee
I wondered where this option went. I could always drag and drop images with the last software version.
The builder did it.
My original transmission had a standard pan
What's the scoop? A later model extension and filter on a early transmission? Does it have to do with the rear pump?
Deep pans are good for testing minimum ground clearance at the worst possible moment.
Maybe on a motorhome or similar.
I have one of those pans too. Tubes run front to back
Looks like it. A LOT of builders think they can just block off the fluid to the rear pump and that it’ll be fine. It doesn’t work out 99.999999 times out of 100. Eventually it eats that rear pump and sends metal through the entire thing, destroying the rest
