Morning . Ordered wheels from Summit in April , still not shipped...getting pissed.Emailed A&A 2 weeks ago... no reply... love when a business does that
When did they say they would be shipped? Two months and nothing might get my blood boiling tooMorning . Ordered wheels from Summit in April , still not shipped...getting pissed.
We are at 77° and 42% and it is real nice in here. I think ours is 3 ton but we have 2600 sq. ft. It's a old R22 system with a squirrel cage fan as big as your refrigerator. A hundred years ago it had the old swamp cooler system cooled by water from 4 cisterns around the house. Much of the old pipes and valves are still in place including the fan and ductwork.Yep, true for sure, I installed heat and air for 5 years, my home/cottage is 950 square ft, 1 1/2 ton heat pump system, when we leave for the day my humidity sets at 45 and 72 degrees, remember this is a small home so as soon as we open the door here in the south it jumps to 65 percent
My issue is that my AC/Furnace are 38 years old and i keep waiting for one to die but every year they keep goingI had a AC engineer tell me that's the way you want it. A system that is too big will short cycle and it won't run long enough to remove the humidity. When it's hot, my system may run non stop for a few days but the humidity is low. Perfect. 78° and 40% is much more comfortable than 77° and 70%. No need to get it cold but clamy. (like the old stores with the chiller systems do)
Last e-mail I got they said they would ship today . But this is the third New date they sent meWhen did they say they would be shipped? Two months and nothing might get my blood boiling too
A mixed blessing to say the least.My issue is that my AC/Furnace are 38 years old and i keep waiting for one to die but every year they keep going
Most of our heat is hot water. We replaced the old cast iron boiler years back. That saved $100 a month on the winter heating bills. Our A/C is the old system. I would estimate the old compressor unit to be 50 years old. It still works and really works pretty well. Not too energy efficient though. The Compressor and fan are both 220 volt units and the lights will flicker a second when they both start at the same time. Sometimes when it's really hot, I will just leave the fan run constantly and the t stat will cycle the compressor as needed. Air circulation to prevent temp stratification is the key.My issue is that my AC/Furnace are 38 years old and i keep waiting for one to die but every year they keep going
I know where red wood city went tree wise. Hell the are HUGE!I'm pretty sure them plantations are partly responsible for the shortage of lumber in Ca. It takes a whole buncha 2x12s to make enough of those raised beds to cover 150 acres .
Yeah, my heating bills luckily are never over $100 a month in winter... just summers suck, i did put a booster fan in one of the ducts leading to my second floor and that helped a ton.. i should add anotherMost of our heat is hot water. We replaced the old cast iron boiler years back. That saved $100 a month on the winter heating bills. Our A/C is the old system. I would estimate the old compressor unit to be 50 years old. It still works and really works pretty well. Not too energy efficient though. The Compressor and fan are both 220 volt units and the lights will flicker a second when they both start at the same time. Sometimes when it's really hot, I will just leave the fan run constantly and the t stat will cycle the compressor as needed. Air circulation to prevent temp stratification is the key.
Ouch! But damn efficient system. MIL has geo out on the farm. I would like to mess with the limits. It's cold in the winter and warm in the summer. It needs auxiliary heat and a huge dehumidifier to make it comfy.I just had to replace our entire Geothermal system. Everything above ground was replaced. New 6 ton unit, new water heater and separate storage tank as well as steam humidifier$30K
That's set up with the two most common bolt patterns.Hate looking at carb stuff.. kinda wanna run a AVS2, never had any issues with cart/edelbrock type carbs.. but also ran holleys without issue... gonna read all day adn go back and forth in my head for a bit
One thing i don't get is they call this a square bore carb... i thought this was a spread bore?
Ah K.. it must just be the smaller primaries on the AVS2 makes it look kinda spread... will prolly get a 800avs2... reading up bout a newer one they have also a VRS or something... still early hereThat's set up with the two most common bolt patterns.
But the difference in throttle bores you see there are not spreadbore.
This is a Holley 4165 with a 'Spreadbore' throttle bore positioning and bolt pattern.
Mine runs like a faucet. (Evap. drain) LOLThe ac shold take the humidity out from the condensor itself should have a built in drain.
I forget. What's this for?Ah K.. it must just be the smaller primaries on the AVS2 makes it look kinda spread... will prolly get a 800avs2... reading up bout a newer one they have also a VRS or something... still early here
Eventually 408/trick flows... first year 318/trickflows.. which 800 is too large but rather not buy a second carb..I forget. What's this for?
You will find it eventually. It will be the last place you look.Eventually 408/trick flows... first year 318/trickflows.. which 800 is too large but rather not buy a second carb..
I SWEAR i have a 750DP somewhere and i can't find it which is really annoying...
Its hard to tell without something to compare with.Ah K.. it must just be the smaller primaries on the AVS2 makes it look kinda spread... will prolly get a 800avs2... reading up bout a newer one they have also a VRS or something... still early here
