It was a total. Not much body damage but K member and it sheared the sump off the oil pan. It popped the bags of course. Probably a ditch ride.Minor patch job.
did you indian head it?Adding diff fluid back in and leaking constant from the bottom of the cover. Any tricks
Flex seal could have fixed the pan Hoppy swears by it.It was a total. Not much body damage but K member and it sheared the sump off the oil pan. It popped the bags of course. Probably a ditch ride.
His prices are fair.Rear sway bar for a early Barracuda? [FOR SALE] - Rear sway bar off 65 Formula S cuda
Well I don't drive much past 30mph.His prices are fair.
I do not beleive any rear sway bars were sold with A-bodies until the 70s.
When Harvey et al were developing the Team Starfish cars they found rear bars created snap oversteer at high speed.
Steve Wall found the same when he tried one out on his '68 Notch at Willow Springs. He's posted pics and/or video
Maybe we can fix that!Well I don't drive much past 30mph.
But not in the City! LOLMaybe we can fix that!
Probably cracked around bolt hole. Or distorted from jackingAdding diff fluid back in and leaking constant from the bottom of the cover. Any tricks
Usually is.Probably cracked around butt hole.
Should help over all the speed bumps ever 100 ft.Verts have more weight on the tail than even the glassbacks. Still would want to use the smallest rear bar and large front. Probably OK on the street especially if careful on downslpe turns, especially in the wet.
?????did you indian head it?
This is what you should use on almost everything... it will never leak.. on my 8 3/4 i do a coating of this on the housing, and on the pig and use a paper gasket?????
Got some gasket sealer going to use that instead of paper gasket and original cover
Honestly. Between all the bike lanes that nobody follows, or use, that have cut down traffic lanes. Then the speed bumps like I posted before. Not to mention road closers for construction everywhere,. Then trying to park. Most neighborhoods have cones and or trash cans holding spaces. I've had more then my share of discussions over the years about those when I moved them.But not in the City! LOL
Those knuckleheads taken things too far.
Sure they use 'em.all the bike lanes that nobody follows, or use,
Dont use on anything you want to get apart!!!This is what you should use on almost everything... it will never leak.. on my 8 3/4 i do a coating of this on the housing, and on the pig and use a paper gasket
P.S. it sucks to clean up later if you remove parts but you will never have a leak.. i use it on almost every gasket on a motor/car
Also.. the smell is addictive... you can pick the stuff up and any autoparts.. been using it since i was like 15 and never had any car leak on me
Meh... just takes a sharper chisel **** works though! i use it on everything cept the chinawall..Dont use on anything you want to get apart!!!
Ill never use it again. Real pain to remove later.....Meh... just takes a sharper chisel **** works though! i use it on everything cept the chinawall..
Yeah.. i just rebuilt my rear end then got a 4.57 pig to put in... not gonna enjoy cleaning it upIll never use it again. Real pain to remove later.....
I need to hit the red X on that one.This is what you should use on almost everything... it will never leak.. on my 8 3/4 i do a coating of this on the housing, and on the pig and use a paper gasket
