Stop in for a cup of coffee
I'll use that on a thermostat housing but I can take that to the wire wheel on the bench grinder to get it off.
This is what you should use on almost everything... it will never leak.. on my 8 3/4 i do a coating of this on the housing, and on the pig and use a paper gasket
P.S. it sucks to clean up later if you remove parts but you will never have a leak.. i use it on almost every gasket on a motor/car
Also.. the smell is addictive... you can pick the stuff up and any autoparts.. been using it since i was like 15 and never had any car leak on me
I use it too
I use it also,,,,But not on everything. On Diff's I will clean well and use RTV sparingly. with my finger. No problems so far... :thumbsup:
Back from car show @ Farrow . Man he has some nice cars!
He is building a road runner back to original !
Viper motor
Lots of nice Mopars
Another Viper motor.
Notice the sticker @halifaxhops .
Truck is ready to go, fire extinguisher at the ready. Pop up shelter for shade and a couple extra chairs. kim is making ice for the cooler, im amazed how well the countertop ice maker works.
Not for everything, but it is good stuff. Usually to stick a gasket to one side and nothing on the other this is what I use.Not for all surfaces where I'm going to need a jackhammer to separate it later. Full seal I would more likely go RTV
Hey guys, one of my college buddies from New York has come across another Mopar guy local to him with some parts for sale...
He was asking me what this intake is, and we think it's a factory 318 poly dual quad intake....
Is anyone looking for one of these, I think he can get a hold of it if someone needs it, let me know...
Same here brother, hope your labs and check up goes well Monday.
Mikie put out a bunch of water this morning, filled my wicking tubs, watered my Japanese maples heavy, and all of my wife's raised bed garden... Time for a shower
Those look great!!!
You say tomato, I say tomato... (It doesn't come out right in text, you have to say it to hear the difference...)
My back yard is mowed and ended up doing the neighbor's as well. He called me up from work(drives truck) said he wanted to hire me cause his regular guy is on vacation. Relatively small, but not as easy as my lawn. A lot of it is sloped, a drain ditch etc. So had to push mow part of it. That sucked. Offered what he pays the other guy... I will probably accept enough to refill my gas can...
casting number 1822004 is for a 57-58 318 with WCFB's as per the white part and casting number book.
It was a total. Not much body damage but K member and it sheared the sump off the oil pan. It popped the bags of course. Probably a ditch ride.
Funny thing about that, when I was using my salvaged 6.1 from a Wrecked challenger I wanted a OEM radiator. There was just not one to be had I mean anywhere, even the Mopar boys in Portland at Wildcat. One of my last calls searching for the radiator the guy at the salvage yard hears my frustration and just tells me “ Sonny don’t nobody wreck them cars backing up”
:rofl: :rofl: :rofl:
