Took three weeks to heal, and still a nice scar....But....What the hey....I gots plenty of scars.....That was my most recent memory...
Your pain, my gain.![]()
Hope that all healed up well Mitch!
![:lol: :lol: :lol:](/mopar/styles/default/xenforo/smilies/smiley-face-laughing.gif)
Depends on your equipment.For parts and such, what pressure? I'm guessing start at about 50psi or so??
Even I learned the first time!
Bet that stung.
No wonder you have thick skin brother.Took three weeks to heal, and still a nice scar....But....What the hey....I gots plenty of scars.....![]()
It's not bad here and I'm in the garage.Good morning. Wolfe take it slow. Keep in yhe shade and drink. Water....
So, you say use the same in primary case as transmission . yes ?
I would do a bit of research as I think the modern SnS may actually circulate engine oil thru primary. I know they changed a lot of stuff (for the better) on oil system. Let me check with my Brother real quick. He will remember.So, you say use the same in primary case as transmission . yes ?
Pulled the bumper , valance, and hood. Grill is next. I'm taking lunch . Blood sugar is low.
yepYour hood is fiberglass on the 64, correct?
Good to hear. Ya, a bearing or a metal bushing would be the best.Seems like I fixed the Demon. The lower bearing disintegrated. The steering shaft also had a wobble to it. Got it mostly straight and found a ball bearing that will work for a while, or forever. Will test it after lunch, but in the garage, it works as it should and used to.
Floggers and wet spots?Well a bit of lightning ended my brush hog session, I’m gone for a couple of hours and we got foggers and floggers, wet spots and car shows. It is official we are once again in the ditch. Might as well put mudders on this thread as we are never actually on the pavement, always in the ditch!
Doesn't seem bad here till you do some work. Humidity... I figured it was cool enough to wear jeans and get them 2 stumps chainsawed up and wheelbarrowed them down to the woods. I'm about soaked. Changed into shorts to go level out the dirt some.It's not bad here and I'm in the garage.
You want to cover every bit you can. It will be through you hair, in your ears, between your toes, up your a__. You get the idea...Oh... plus gloves and face shield. Lessons learned from those on here that do their own stunts!
You want to cover every bit you can. It will be through you hair, in your ears, between your toes, up your a__. You get the idea...![]()
Keefer try bio splat on the bees?
For those who have never did this, it's a. It's a *****....Finished replacing screen on my RV. Blue tore it to **** when we were in NY. She was at hoppys. That is another story...
You need one of those old-school kick panels on the bottom partFor those who have never did this, it's a. It's a *****....
