Unconventional
Bonneville still has some wet spots. No mention in the article about postponements. Inspection started yesterday.
The paint is crap anyway. but the stuff is for inside a house, so I don’t think it would hurt.Might Eat the Paint ?????
KKKKKKKKKKKThe paint is crap anyway.
Yep best shakes on the planetMe too, several times. interesting place to visit. Used to stop there when I went to Sturgis every year.
Not a bike guy, but after I did DD check it looks like your on the right track.I'm finding out that there's a lot of confusion as to what engine oil to use in this thing. I think I'm going to use 20W50 conventional in the engine. But then there's confusion on weather the primary shares that are not. Think I'm going to put 75W140 synthetic in the transmission though
I called you as requested.20-50 worked well on the 70 sporters I had. just sayin.....
Typically SAE 20W-50 for motor on original shovels. Primary on original shovels, does not share engine oil. I just do not know anything about the modern shovels produced by SnS. Primary is typically 80wtI'm finding out that there's a lot of confusion as to what engine oil to use in this thing. I think I'm going to use 20W50 conventional in the engine. But then there's confusion on weather the primary shares that are not. Think I'm going to put 75W140 synthetic in the transmission though
A late good morning
Had to make a run into town early. 5 shot-Americano might have been overkill... dunno but I'm runnin' rich
Picked up a 20# blaster to do some parts cleaning. Coarse Walnut shell and fine silica media..... saved $42 with a couple of coupons
Replied!Oil
And a mask.Oh... plus gloves and face shield. Lessons learned from those on here that do their own stunts!
I started on the Valiant about 2 hours ago . Light headed not making much progress.
So, you say use the same in primary case as transmission . yes ?Typically SAE 20W-50 for motor on original shovels. Primary on original shovels, does not share engine oil. I just do not know anything about the modern shovels produced by SnS. Primary is typically 80wt
215 800 or 215 537, or ......Replied!
And a mask.
Yup.....Oh... plus gloves and face shield. Lessons learned from those on here that do their own stunts!
The fine silica should work best.A late good morning
