Do you have that in floor heater? My grandma had one like that instead of duct work through the house. MIL had a oil furnace but with ductwork.
$$$$$$$$I am so on the fence on filling the heating oil tank full now. Two reasons its been buried for who knows how long, but clean and no water in it. And it is 500 gallons.
Have it pressure checked, local farm fuel supplier will do ours for 50 bucks.I am so on the fence on filling the heating oil tank full now. Two reasons its been buried for who knows how long, but clean and no water in it. And it is 500 gallons.
I did hear it. It all happened so fast I was more concerned with not flippingHow did you not hear that?
Dam thats great!I still have oil for heat plus the wood stove. Propane for hot water and cooking. Around $500 for the year.
No that is just propane. Oil around $1000Dam thats great!
So a thousand on oil gets you thru a season, I have oil, baseboard hot water spend about $1'400.00 on averageAnd that is NOT burning wood. I wasn't up to keeping the fire going. Lazy I guess
yepSo a thousand on oil gets you thru a season, I have oil, baseboard hot water spend about $1'400.00 on average
Whoa!Long story but we had to replace the whole geothermal system. Everything above ground, just done in May and it cost 30K
I have one also need to put up a omni directional one. And have a amazon fire stick works well as a combo. You get alot of free bees if you have a amazon membership which i do since I buy alot from them.And I have roof antennae and get 26 channels but then I am on top of the world here
Ouch,Long story but we had to replace the whole geothermal system. Everything above ground, just done in May and it cost 30K
Ah, makes sense. We have hot water heat too. Weil MacClain energy efficient nat.gas boiler.So a thousand on oil gets you thru a season, I have oil, baseboard hot water spend about $1'400.00 on average
MIL is replacing here system out on the farm. It was a pump and dump system when they had livestock. Now it will be just for the house. (dumb contractors put that original system in.)Long story but we had to replace the whole geothermal system. Everything above ground, just done in May and it cost 30K
