Yeah next 10 days possible rain, hopefully we get some
What she idles perfect, in gear and out, what you seen was a true cold start, hmmmm.Hey the first sputters sounded good. Get it to idle mike?
Can’t sleep. Thunder and lightning woke me up at 0200. I thought good we need rain, after all the racket not one drop
Here you all go, as promised coffee crew first, here is the three videos together, yep, I am a fat old hickory nut from ARKANSAS, and yes, I promise it was a cold start
He’s still sleepingWhere the hell did you hear sputtering Ray @halifaxhops
To early to get punked...He’s still sleeping
Just the running out of gas thing, should have rephrased that.Where the hell did you hear sputtering Ray @halifaxhops
Thanks as always Matt. I have been saving everything you send. This made sense and I have a couple squirters on order to try and drillIf there's no hesitation when slowly opening then, I think the larger nozzles are worth a shot.
I'm going with Shrinker's explanation here, which I'm not sure I fully understand, but think I do.
Paraphrasing, he said that the pump shot is needed to rewet the intake manifold which evaporate with the change in pressure. Something like dew forming on surface but in reverse.
Once the throttle are modeately open, shouldn't need pump shot. The venturi's will keep fuel flowing matching airflow. The challenge is the low speed circuit which is dependent on manifold pressure.
Yep, that was my very first start up, your dizzy, my degree set.. yes, to hear her fire up back last winter was an exiting day alsoJust the running out of gas thing, should have rephrased that.
Safe travels and enjoy those very cool temps 67 here this morning.Morning here for an early cup of wake up. Heading to Kansas City this morning Cheryl has an appointment with Golf MD.
Rain and cooler temp setting up here currently 55 outside we haven't seen that in a few months...I'll take it.
Think it is a pushbutton one. Just thought of that
Already broke in, 3 thousand miles on it in a truck with 3.55 gears. I am getting 70 cold oil pressure at 11 hundred rpms, 46 at running temp.It sounds almost ready to go break in next?
Same with me but no thunder. The day before I overslept. 10 hours total. Haven't slept that long in months. Now last night, asleep at 11 and awake at 4. I hate that. I can see a nap after lunch today.Can’t sleep. Thunder and lightning woke me up at 0200. I thought good we need rain, after all the racket not one drop
No...not unless they are on Parole and even then...several attempts of killing yourself is allowedHoly heck batman. PA just made Naloxone a over the counter drug for $45. Of course, people are complaining I can't afford it. I used it four times last week the person being interviewed said. Should they not be in jail?
