- Joined
- Mar 17, 2018
- Messages
- 14,415
- Reaction score
- 33,349
I thought you were an MP?I’m an army grunt, that don’t bother me
It will work. I know from experience. It’s a heavier mount. You may have to shim it on an LA depending on which pulleys you have on your crank. My spare bracket is actually on my buddys 360 in his ram chargerBTW.. wish i had gone with a older style water pump.. i have to figure how to make a power steering bracket (i had no idea) haven't checked if my old alt bracket will work from the poly...
Thats funny right there!I thought you were an MP?
All soldiers are infantry first. Mos second or so they claimI thought you were an MP?
Besides. All we are are glorified mech infantryI thought you were an MP?
Yep. I wish I could have joined lolSo for the space force your always a space Cadet? To the chow hall and Beyond!
Actually, let me look, I have a spare 318 LA parts lock, I may have the alternator bracket you need.BTW.. wish i had gone with a older style water pump.. i have to figure how to make a power steering bracket (i had no idea) haven't checked if my old alt bracket will work from the poly...
Do you have to wear a red shirt until you make E-4?
I still can’t believe they’re actually funding this serviceDo you have to wear a red shirt until you make E-4?
Doubt it it is still part of the USAF like the marines are part of USN. Bet they run Norad now.Do you have to wear a red shirt until you make E-4?
I'll look at my current one, i can't see why it wouldn't work.. the power steering one is a pain but will be fun making a bracket i hope I need to take apart the alt and clean/grease the bearings.. hoping i can save it alsoActually, let me look, I have a spare 318 LA parts lock, I may have the alternator bracket you need.
I’m running a power steering gear box and pump of a 73 duster. I had to put a single washer between the bracket and the block to get it all to align.I'll look at my current one, i can't see why it wouldn't work.. the power steering one is a pain but will be fun making a bracket i hope I need to take apart the alt and clean/grease the bearings.. hoping i can save it also
Yeah, i'm trying to keep my original box/pump... don't wanna spend more money Speaking of.. time to order a starter....I’m running a power steering gear box and pump of a 73 duster. I had to put a single washer between the bracket and the block to get it all to align.
Brand new Delco starter is $71 on rockauto... cheap enough Need to get new ground and positive cables also.. kinda shocked at what they cost..Look in marketplace first. Tons of new ones there.
Like Vandenberg SFB/space force base. Few years ago they knocked down a bunch of the base housing that was actually across the highway from the main gate and pretty much unsecured and filled the area with a solar farm. I don't know if they added housing inside the gate or just reduced the size of their staff to jive with the reduced housing.Doubt it it is still part of the USAF like the marines are part of USN. Bet they run Norad now.
Well if you need the bracket, let me know. It’s free…Yeah, i'm trying to keep my original box/pump... don't wanna spend more money Speaking of.. time to order a starter....
