Mine too. And you can keep the snow flurries. It’s chilly here but not that chilly.
I still think Elvira is hotter but I do like her in her OEM status as well!
Looks much smaller! Did they shrink it?Took dog to groomer. I dont think we got the same dog back….
Chevy squarebodies use a 6 port valve, supply and return that switches between tanks.Sooo question. Anyone here ever custom plumbed a second tank into a vehicle?
My 78 has a 15 gallon tank. With 4.56 gears and 33s, and a granny 4 speed, 6-7 mpg is lucky. The truck factory has its tank on the drivers side. However my bed is actually set up for a passenger side tank(California model according to research) but also has the provisions that I can punch out for a drivers side tank. I have a spare tank so I thought about mounting both tanks but not sure how to plumb the two of them together.
Only if the outlets are on low side of tanks.Just plumb it. T it. Those tank switching valves are a pain in the azz. It will seek it's own level between the two
That might be the easiest.I was thinking that, or running a transfer pump from one tank to the other.
Yeah I want to avoid those. Dads old 81 Chevy went through multiple of those before he finally just said the heck with it and we only used the passenger tankChevy squarebodies use a 6 port valve, supply and return that switches between tanks.
Yup, they were problematic, aftermarket ones were not very good. So, transfer pump and gauges for both tanks. Easy enough to flip on a switch and shove fuel into main tank.Yeah I want to avoid those. Dads old 81 Chevy went through multiple of those before he finally just said the heck with it and we only used the passenger tank
18 here this morning with a north wind. Our warmup starts today 60's through next week...is it spring yet??30 degrees here, looks like 22 to 24 up near sublimeone, back to the 70es for the high Monday. Be happier when this big cold front is gone.
Agree. Fall is my favorite time of year, beautiful colors and temps. However, then all the leaves are gone and we have approximately 5 months of cold weather...is it spring yet??
