Ddaddy
I'm changing the World... one pixel at a time!
Good evening folks! Checking in late since I just got home from my daughter's band concert.
I also got the fuel pump blanking plate off the GTS earlier today and sure enough, it was warped causing the leak. Both the top and bottom edges were bowed out by about a 1/16". We just flipped it over so that the center where the bolt holes are was then bowed out and torqued it tight with a new gasket and sealant. Checked it afterward and it was true flat from top to bottom.
I will let it cure overnight and do some shake down runs tomorrow and confirm that it's fixed.
