Sorry you did say mirrored...The 64 radiator intake is mirrored to the 66.. passenger side of the cap
Found this image online
They worked well at the rock farm, even down into the feed tunnels.Got new walkie talkies today for use on power Tour. Vhf business class. 5 watt
Looks like that one fits perfect
Yeah... that looks like the hose that RockAuto sent me. It states it's correct for 64 but nay
Always somethingYeah... that looks like the hose that RockAuto sent me. It states it's correct for 64 but nay
Works perfect with that al-u-min-e-um radiator.My contribution for the month. Pic from last year .
Auto zone.
That's how most Israeli folks say it.Works perfect with that al-u-min-e-um radiator.
Mike, I have been doing the same thing for many years. Anytime I have a situation where the stock hose will not fit. I either went through the racks in my store to pick out one with the correct angles, or after I retired, I go right into the parts store and go to their hoses and pick out the one I like that will fit the best..I went in tthe back room at NAPA and picked this one out. Lord knows what it fits.
Sounds like some women shoppers I know.Mike, I have been doing the same thing for many years. Anytime I have a situation where the stock hose will not fit. I either went through the racks in my store to pick out one with the correct angles, or after I retired, I go right into the parts store and go to their hoses and pick out the one I like that will fit the best..
That'd be itMy contribution for the month. Pic from last year .
Auto zone.
The store local here had it in stock.That'd be it
It’s very hard to find correct molded ones of those. And the springs that used to go inside, impossible to findFreaking upper radiator hose... seems simple enough, right.
What’s weird is I got my 64 polara hose from Rockauto and it fit perfectlyYeah... that looks like the hose that RockAuto sent me. It states it's correct for 64 but nay
Wow, that's a mile off for sure.Oh.. btw... Pinion angle was only bout 8 degrees off.... with a rear u-joint working angle of 12* which is insane... i mathed bad
yeah.. i was tired or stoned and visualized **** backwards.... so just to verify... trans/motor has a -2.5* angle (down) so the rear under load should be +2 so i'm going to set it at 0 to -1... which should make a huge difference.. it had a nasty vibration when it would get like 50mph wheel speedWow, that's a mile off for sure.
Oh I bet. Shake the sh*t out of you.yeah.. i was tired or stoned and visualized **** backwards.... so just to verify... trans/motor has a -2.5* angle (down) so the rear under load should be +2 so i'm going to set it at 0 to -1... which should make a huge difference.. it had a nasty vibration when it would get like 50mph wheel speed
I have always done the same, with exception that I bend a welding rod as a pattern then hit the rack and find the closest one and trim to fit. Works every time. The old counter guys never had an issue with letting you do it that way. I can only imagine trying to explain that today to a pup behind the counter while he is asking repeatedly what year is the car as you in vain explain over and over it will not help, the motor did not exist in that car.Mike, I have been doing the same thing for many years. Anytime I have a situation where the stock hose will not fit. I either went through the racks in my store to pick out one with the correct angles, or after I retired, I go right into the parts store and go to their hoses and pick out the one I like that will fit the best..
Holy smokes. I can see why it shook you to pieces!Oh.. btw... Pinion angle was only bout 8 degrees off.... with a rear u-joint working angle of 12* which is insane... i mathed bad
A chunk of flexible hot air tube works great as well . Like the stuff used from the exhaust manifold heat stove to the underside of the air cleaner snorkel. I had a chunk laying around and it worked really good. I know MacGyver.I have always done the same, with exception that I bend a welding rod as a pattern then hit the rack and find the closest one and trim to fit. Works every time. The old counter guys never had an issue with letting you do it that way. I can only imagine trying to explain that today to a pup behind the counter while he is asking repeatedly what year is the car as you in vain explain over and over it will not help, the motor did not exist in that car.
