Any coulour you like, have a Great Day All!
Why?Got a map?
Where's the nearest parallel road that has a bridge or is far enough away?
Not a charger. It’s a 68 satelite/roadrunner,m68 charger? Has the GTX thing also a bit?
it is a 69 Dodge in that pictureNot a charger. It’s a 68 satelite/roadrunner,m
Superbee just being a trim level of a Coronet. Could be either, wouldn't know without the VIN. Otherwise the same car. 100% it is a 69 Dodge Coronet as a base, could be a upper trim level though.Good Morning Mitch, Superbee then?
Then Coronet would be my guess hahait is a 69 Dodge in that picture
Train wasn't moving. That could be a long wait.Why?
It has the '69 side markers69 Coronet or Super Bee. Rectangle marker lights, fake vents in the rear quarters and flush grill and lights
coil over shocks added about a inch to mine. Towing shocks.Soo... just curious.. now that my springs are installed properly and have settled i have like 1-1.5" of space between the tire and the outside inner wheel wells, it looks great with the tires tucked in but i don't feel like bouncing off them over bumps. So.. my front spring mounts do have a lower hole but will add negative pinion which i can't really do. Was just wondering if 1-2" longer shackles would raise it much? And yes.. i hate the long shackle thing but i'm not talking thunderbolt and lightfoot... and the factory ones are pretty short.. Are there downsides to slightly longer ones?
Also thinking of how i might modify the wheel wells to keep the lower ride height due to awesomeness.. but not sure how much room i have due to how the quarter rolls in.. Funnily i have plenty of room at the wheel lip..
P.S. these are new ESPO +1 springs so i am not up for buying another set now...
What are you trying to do?Soo... just curious.. now that my springs are installed properly and have settled i have like 1-1.5" of space between the tire and the outside inner wheel wells, it looks great with the tires tucked in but i don't feel like bouncing off them over bumps. So.. my front spring mounts do have a lower hole but will add negative pinion which i can't really do. Was just wondering if 1-2" longer shackles would raise it much? And yes.. i hate the long shackle thing but i'm not talking thunderbolt and lightfoot... and the factory ones are pretty short.. Are there downsides to slightly longer ones?
naw.. just a street beater, was thinking of just like 1-1.5" more lift but i think i'm gonna look at modifying the wheel wells first, would like to keep the stance..What are you trying to do?
Mopar leaf springs should be nearly flat when static for most uses.
For drag race launch, there should be some arch. Longer shackels can be used to get a little more swing (unfortunately also allows more sideway but not an issue for straight runs) as long as they angle back from the frame to the rear spring eye.
If more anti-squat is needed, then raise the front spring eye. That's when a longer shackle is probably most needed for a drag car. For road race the lower hieght reduces the roll center, and roundyround/road racing/rally/street can't take advantage of unclamping the rear half the spring pack - nor should they need to.
Correct the pinion angle with shims. IIRC Speedway has 'em 2.5" wide.
There is side movement when going around turns - more so the higher the rear is jacked.naw.. just a street beater, was thinking of just like 1-1.5" more lift but i think i'm gonna look at modifying the wheel wells first, would like to keep the stance..
The spot that might hit the tire is a soft rolled area so no chance of cutting a tire but rather not have them hit at all.. right now it would take a pretty good bump to hit i think..
just thinking out loud..
Just watch how close they come to the fuel tank lip. The previous owner of my 65 used the clamp ons. I went over some RR tracks and the spring caught the lip and ripped the tank out. It skidded down the highway behind me until I out ran it . No fire and it stopped skidding with the fill tube up so it didn't spill gas.
The English versionCentre link, what's that lol : )
