Those are rare. Would love a set in 6 inch width.....Not Mine - hard to find 15" small pattern wheels
Cragar SS 15" Mopar - 1 pair of 4" Small Bolt Pattern " PRE-1973 " A-body Wheels .
Wouldn't Everybody like to have a 6in set up.....Or more .........Those are rare. Would love a set in 6 inch width.....
he did say 6" width. I don't want that set upWouldn't Everybody like to have a 6in set up.....Or more .........
"Beer Can" Orange is the new black...he did say 6" width. I don't want that set up
Could be a good candidate for blasting and powder coating? Maybe a Dart with SS fenders cut out?I hate to say but those Cragar's are not all that good. The seller mentioned one was chrome peeling. 15x8 will fit a Duster and that's about it.
They would fit there.Could be a good candidate for blasting and powder coating? Maybe a Dart with SS fenders cut out?
So. We all know about my trans issue. We'll, on further thought and inspection, it was not just the converter. Rear band was burned out as well....
I'm no tranny expert so trying to figure out what would cause that to happen???So. We all know about my trans issue. We'll, on further thought and inspection, it was not just the converter. Rear band was burned out as well....
Without putting undo shade on rebuilder, it happened because of the HD spring in the rear servo. Cheetah valve bodies mandate standard spring. Warns in no mistaken terms if you use HD spring your rear clutch will burn out...I'm no tranny expert so trying to figure out what would cause that to happen???
AKS Hoppy.......KKKKKKKKI'm no tranny expert so trying to figure out what would cause that to happen???
Especially Back Reading ...Reading is fundemental!
First sign was the fluid smell like buttered popcornAKS Hoppy.......KKKKKKKK
Does the replacement trans have the heavy duty band?Now, the transmission was not provided with the cheetah valve body. I supplied it after fighting the one supplied to shift at all. There is that. But before using new valve body I asked rebuilder about warning. Don't worry about it was his response. But he did make good on provideding a replacement unit no charge..
No. Standard servo spring...not band...Does the replacement trans have the heavy duty band?
Well at least that mystery is solved.No. Standard servo spring...not band...
