Just seeing this! in full production!Wonder where they are at with the Hemi build they want to do? @Johnny Mac
Chrysler Gen III Hemi Compatible - 426 c.i.
Yep, She got the carpet a couple times. Others on hard floor and a throw rug that I just took outside and hosed off.O man that sucks! Hope you don’t have carpet, we got none and I think it may be the smartest decision we made when building the house. Jodi got one of those robotic floor sweepers that just runs around and sweeps for ya. German Shepard hair is a thing!
Thanks Fred, But I already know they are different. Good man you areHey Mitch I have a rebuilt master brake cylinder for my Scamp I never used and was thinking it might be the same as your Cudas.
Just a thought but if the #s are the same I can help. Pictures on the way.
He said ‘numbers matching’ Didn’t even know that was a thing for master cyl…Hey Mitch I have a rebuilt master brake cylinder for my Scamp I never used and was thinking it might be the same as your Cudas.
Ya, believe it. The one I'm rebuilding is the original...and... its properly date coded.....He said ‘numbers matching’ Didn’t even know that was a thing for master cyl…
Well **** I guess I don't need pictures but I already down loaded them so here they are if someone needs it.Thanks Fred, But I already know they are different. Good man you are
I'm sure someone will be happy to use that......Well **** I guess I don't need pictures but I already down loaded them so here they are if someone needs it.
also a good starting point for a LS/6spd conversion!
Don’t let him fool ya Mitch, ya turn your back for just a moment and he is drinking your whiskey and feeding your dog treats!Thanks Fred, But I already know they are different. Good man you are
I been found out. Thanks for telling on me John.Don’t let him fool ya Mitch, ya turn your back for just a moment and he is drinking your whiskey and feeding your dog treats!
And not cheap to paint the whole car.k.. taillights back in.. sanded out runs, will reshoot and blend it good as i can... kinda itching to paint the whole car.. but that's for another year..
About 1200 in paint, primer and clear plus the mixins alone for the dartAnd not cheap to paint the whole car.
Buy it by the kit, it’s actuallyShouyld be able to do it under 1k if i could make 1 gallon work.. i believe a gallon from tcp was 340 for my red.. +activator and whatever else.. BUT.. that's far future.. first goal is drive and iron it out
Which red? I’m going with rally red for my truck from them. Paint kit is 400Shouyld be able to do it under 1k if i could make 1 gallon work.. i believe a gallon from tcp was 340 for my red.. +activator and whatever else.. BUT.. that's far future.. first goal is drive and iron it out
yeah.. will figure that another time.. only thing that scares me and why i don't wanna paint it is trying to get trim off the front/rear windows.. a: wrecking the trim and B: hurting a window i can't replace.. everytime i have seen people try to tape around trim and paint, you can see itBuy it by the kit, it’s actually
Cheaper that way
That's not bad. Last time I bought quality primer it was over 400 bucks a gallon and good clear was about 500 a gallon.About 1200 in paint, primer and clear plus the mixins alone for the dart
the 1962 vermillion/cherry red... in acrylic enamel... i didn't realize how bad urethane is to paint.. for lungs and ****.. gonna wear my mask for now onWhich red? I’m going with rally red for my truck from them. Paint kit is 400
I have the same fear on the truck cabyeah.. will figure that another time.. only thing that scares me and why i don't wanna paint it is trying to get trim off the front/rear windows.. a: wrecking the trim and B: hurting a window i can't replace.. everytime i have seen people try to tape around trim and paint, you can see it
the upol urethane primer i have been using is $50 a quart.. better deal as a gallon i'm sure.. that's with hardner.. and is DTM, can use as a sealer also depending on reductionThat's not bad. Last time I bought quality primer it was over 400 bucks a gallon and good clear was about 500 a gallon.
That’s why I have the fresh air breathing systemthe 1962 vermillion/cherry red... in acrylic enamel... i didn't realize how bad urethane is to paint.. for lungs and ****.. gonna wear my mask for now on
yeah.. this is a 1 year only car.. and the rear window is in a point in the middle.. even transporting one would scare meI have the same fear on the truck cab
