yeah.. i'm not a painter but i'm happy.. i reduce it a little and it lays down super flat and has really good fill... i hit with 400 before throwing paint on and comes out okNever used it but has good feed back.
Ok, date coded…Ya, believe it. The one I'm rebuilding is the original...and... its properly date coded.....
Even my last priming I use a long block and 320 grit then 600 but just me making sure I got it straight enough. At my age I need the extra help.yeah.. i'm not a painter but i'm happy.. i reduce it a little and it lays down super flat and has really good fill... i hit with 400 before throwing paint on and comes out ok
yeah, i tried to get by with a 4" sanding block and finally got a longboard and holy crap what a difference.. i woulda saved soo much timeEven my last priming I use a long block and 320 grit then 600 but just me making sure I got it straight enough. At my age I need the extra help.
It doses make a difference.yeah, i tried to get by with a 4" sanding block and finally got a longboard and holy crap what a difference.. i woulda saved soo much time
That’s half the price than on TCPs websitethis is the primer btw..
PRimer
The kit I ordered from there I for the truck was 400.89 with a gallon of color, gallon of reducer, gallon of clear and gallon of hardner plus filters and mixing stuffThis is the tcp for 62 red.. $342 a gallon and 46 for hardner.. so basically $400..
[/URL]
Recently scott painted his renault with nasson black single stage and my god it looks amazing.. like a foot deep super glossy, really impressive
all that for 400? wow man.. that was from tcp?The kit I ordered from there I for the truck was 400.89 with a gallon of color, gallon of reducer, gallon of clear and gallon of hardner plus filters and mixing stuff
That looks tasty. I had left overs.Well dinner if anyone is hungry. Somewhere under the cheese is mini weenies, and Maple Baked Beans.
Frozen Pizza around here sucks, also any ocean fish. Better off getting Tuna or Salmon in a can.had frozen pizza for the third night in a row.... these home run inn pizzas are amazing
Next time you hit a big store look for Motor City Pizza CO.. it's outstanding.. but the home run in is amazing.. where are you in ND?Frozen Pizza around here sucks, also any ocean fish. Better off getting Tuna or Salmon in a can.
Yesall that for 400? wow man.. that was from tcp?
wow that is crazy... i never shot bccc, seems like a lot more work.. but i like that price
Center of the State all the way to almost the top. Bisbee is the town.Next time you hit a big store look for Motor City Pizza CO.. it's outstanding.. but the home run in is amazing.. where are you in ND?
Base clear is better and easier than single stage. You can wait about 24 hours before you put the clear coat on without sanding it.wow that is crazy... i never shot bccc, seems like a lot more work.. but i like that price
i figured it would be harder than just throwing singlestage of a solid color down.. maybe one day i'll try itBase clear is better and easier than single stage. You can wait about 24 hours before you put the clear coat on without sanding it.
Also if you put a bit of the color in the first coat of clear it makes the color stand out a lot more. And depends on the paint you use so definitely read the directions first.
I think you'll like it better.i figured it would be harder than just throwing singlestage of a solid color down.. maybe one day i'll try it
