Stop in for a cup of coffee
Hey did you chage the backing plates and brake size? Think it should have come with 9" brakes.
I thought that ended in 62? guess i'm wrong.. but still same idea.. mine in 62 meets right under the drive shaft in the middle.. very safe :)
I'm this short. If I apply a lot of force and pull the arms in the drums forward I can get the bracket to touch but not through enough to thread the nut
Then the cable will pull forward more need to know how far back it is with them on the adjuster arms will pull the cables back. If you do get that cable on with them off no way the drums will go back on.
Someone go pick up this block for me :) Such a good deal
Me I would put them on and measure and see how far off it is. Those adjuster arms are wat to far forward in the pic.
The way I have always done rear brakes back the parking brake cable off a few turns, install the shoes drums on adjust the shoes then the parking brake if that helps explain it
To keep with the current mode of satire....Whack it off and put an allthread bolt and extend your bolt
Call Inline and ask. If you cut the bolt closer to the cable and put one of those long nuts used for althread you can extend the length of the bolt maybe even use a piece of all thread to extend it more. I would put a locking nut on against the long althread nut to keep it from coming loose
