ScampMike
Despicable Damn Yankee
the main wire pack thingymebop.. yea yea, that's it
as said, I'm sure Klingers has everything to get it back to stock wiring at least. Do you think it started from the bulkhead? I know that is a common trouble spot. I got my headlights off it with relays, but have not done anything about the rest of the load going through to the amp gauge. Although, the connectors showed no issue on mine. I did have them apart, cleaned and put back with dielectric grease.
wow - that's not bad at all
yea, a little shot of that would do itI use white grease myself on any inside stuff like wiper pivots etc.
I have dealt with them before and gave them a list of what I needed and length and they send me a invoice for it. Usually 25' min on each ga/color. Really reasonable to me and the terminal ends for the connectors are easy to get. I am lucky that I have re wired aircraft and know hoew to do it.wow - that's not bad at all
the crosses we must bear...
sucks about the Hopmobile - were you saying you need the big connectors? what's it called?
can you pull the terminals out and put them in the other plug?HATE the idea of cutting any of it up - thinking of making an adapter...
