already spent the car budget for the month????
yes, because I bought the C-body clutch pedals this time and that was a real kick to the purse LOL
I would NOT hit that!!!!
needing a bigger rear end.
well, just the ones who want to go fast...
but I really needed the Hookers ...
I wonder if a Dana 44 out of a Box Jeep would hold a slant ...I am thinking it would and is available at the pick a part ...hopefully with some low gears
Nah, I think fabo is tired of build threads from me because I have too many cars and I have not really finished much yet
1965 Plymouth Barracuda Steering Wheel
This a deal?
Sorry, I meant they were taking him into the surgery room. Everything went fine and we're home now, little guy resting, so far he's doing ok
Thanks.
I just did a little poking around google .....seems the Dana 44 was in the jeep grand Cherokees and the DANA 35 was in the box jeep Cherokees
I don't know if either will fit my hot rod early A and what is to be found in the pick a part yet
Some cherokees did get the 44. My 87 had oneI just did a little poking around google .....seems the Dana 44 was in the jeep grand Cherokees and the DANA 35 was in the box jeep Cherokees
does this look like an 8 1/4 to you guys ....I don't know why I am having a brain freeze and I cant tell
either that or a dana 35 - hard to tell from that picdoes this look like an 8 1/4 to you guys ....I don't know why I am having a brain freeze and I cant tell
that is what is in the wagon now that someone put in ....I want to take it out of the wagon and put it in my 75 dart to make a 360/833 od / 8 1/4 combo ...then for the wagon ...get some kind of readily available rear ...even a ford what ever to make a /6/ 833 od / some kind of rear end that can tow a light trailer with comboYep...
man - my work place is blowing up - too much snow, too cold and then we had a science building have an HVAC unit on the roof blow a coil - weeehooo!
My wagon has an 8 3/4 with 2.76 open gears right now... But can change to any ratio sure grip when ready - either 2.76 or 2.93 for economy... I want to build a 20 MPG 360 for it....
She's sitting in the corner waiting for her turn to get finished with most of the parts stored in her so I don't loose them...
New suspension and 10" brakes already installed, body painted, have master cylinder and new brake lines for dual reservoir manual disc conversion... I have a KH set-up earmarked to covnert it to front discs also (even though the front 10" drum set-up is new)...
what are your plans regarding the exhaust ??
