@straightlinespeed what can I do to help
Well, I finally got my taxes done. I figured it would be a mess with the job switch, severance payments and house sale. After wading through it all, I was disappointed that I'm not getting any money back like I usually do (usually a few thousand)...but at least I don't owe anything.
Since I'm not getting anything back, I'm putting off the actual filing until it's closer to the due date.
Beauty of a C body!Had a nice day here, cleaned the Fury's windows and chrome real good (Bon Ami original, yellow can.) Tried out a $$pecial vinyl repair tape, will see how the one test patch holds up before I use any more. Met my young lady friend downtown for lunch. Stopped and took a few pics on the way home. A place that has Frisbee golf and you can do wakeboarding and other stuff there...
And your boss would still like you to believe you are overpaid.I'm making 58% less than the national average, 46 percent less than the state average and 42 percent less than the local average
Ask away
It's all Greek to me!Alright, I bought the barrel below. I just went with a 16" .223 wylde, with a .750 gas block. My question is regarding attaching it, I want a free float hand guard. I've never built one this far yet, and Im not sure if the hand guard comes with the barrel nut, or if I have to buy all of that... Also being its a 16" barrel, I want the majority of the end of the barrel showing. So what length hand guard would you buy?
Ok. Let's see if I can explain this properly.Alright, I bought the barrel below. I just went with a 16" .223 wylde, with a .750 gas block. My question is regarding attaching it, I want a free float hand guard. I've never built one this far yet, and Im not sure if the hand guard comes with the barrel nut, or if I have to buy all of that... Also being its a 16" barrel, I want the majority of the end of the barrel showing. So what length hand guard would you buy?
Sorry forgot to mention, its Carbine length.... Ok the only other stuff I will need is the gas block and the gas tube with roll pin correct?Ok. Let's see if I can explain this properly.
You'll need to find out what length gas system the barrel is drilled for. There's 4 options, pistol length(rare on 16in barrels) , mid length, carbine length and rifle length, the latter three are all commonly found on 16in barrels. That will help determine what length hand rails to get as you'll want your hand rails to cover up to the gas block.
Most of the time, a free float rail will come with the barrel nut. There are a few that don't but those aren't true free floats and are knock offs. I recommend highly a 1 piece free float rail, Midwest industries is a good brand.
Keep in mind, the length of a free float rail is mostly up to you. But you'll want to make sure it covers the gas tube(which you'll need to buy as well) in order to protect it. Those tubes are flimsy as hell and very thin. Easy to damage. For example: you can run a full length rifle rail on a mid length gas setup but you don't want to run the 4 inch pistol length rail on a mid length, carbine or rifle.
Not for the hand rail. The gas tube "should" come with a gas tub roll pin however, buy a couple extra(don't ask how I know this) . Do you have the upper receiver assembled?Sorry forgot to mention, its Carbine length.... Ok the only other stuff I will need is the gas block and the gas tube with roll pin correct?
As you mentioned the hand guard comes with the barrel nut, but I should not need anything else will I?
Also make sure the holes on the gas block are correctly spaced to the holes on the barrel. Sometimes the holes in the barrels are a tad out of spec and may need files slightly
David, that is a very handsome Fury, well done.Thanks, Dave. You know I was not at all sure about buying this car, but more and more I am glad that I did.
how's that back Mr.?It's all Greek to me!
A barrel wrench, torque wrench, roll pin holder/punch, painters tape to prevent marringThe upper only has the BCG and Charging Handle. I have to buy the dust cover and forward assist stuff.. Is there anything else I need for that?
Thanks for the tip on the holes, I'll check that out.
Oh but the upper receiver parts kit instead of individual parts, that way you get the right stuffThe upper only has the BCG and Charging Handle. I have to buy the dust cover and forward assist stuff.. Is there anything else I need for that?
Check, got all that.A barrel wrench, torque wrench, roll pin holder/punch, painters tape to prevent marring
Been trying to find one that is in stock. Looks like I have to buy individual as of right now..Oh but the upper receiver parts kit instead of individual parts, that way you get the right stuff
I'd wait. Where are you lookingCheck, got all that.
RamiCheck, got all that.
LOL, the one place I have not made it to yet... Thanks!
Barely any at all in 5.56, less than 3 lbs. at army basic training, drill instructor put one against his family jewels and fired it to prove there was no recoilI was actually thinking of buying an AR ....I work around law enforcement and one of my best buddies is a Deputy and she is trying to get me to join the force.
She has offered to take me to the cop shooting range.
She told me an AR is a good unit because the recoil isn't bad on a small person like me.
