Third in lineHow do I sign up to get on the list for upholstery work?
Can't you just re tap the holes.So I need help. The previous owner stripped out the screws that hold the passenger rear arm rest on, think I should just drill them out
I could but I gotta get the damn things offCan't you just re tap the holes.
The philips heads are completely rounded out, can't get vice grips to them. I may just get the sawzall and cut between the panel and arm restCan you get a vise grip on the heads and pull while you turn?
What have you tried to use to remove them.
RecessedAre the heads exposed or recessed?
That's what I'm thinking, I tried my screw extractor and the screws are either rusted in too much or the metal too soft, the extractor just spun outDrill the heads off.
He, He, You said Stripped !!So I need help. The previous owner stripped out the screws that hold the passenger rear arm rest on, think I should just drill them out
Let's see what round 1 looks like first..How do I sign up to get on the list for upholstery work?
Wow just wow
Hey, my Johnny Lightning '69 GTS came today! Cool little 1:48 die-cast...
No noIf you post it here somebody will tell you to put a 360 in it!
probably too late now - ez outI could but I gotta get the damn things off
oopps - didn't see this.. humm....That's what I'm thinking, I tried my screw extractor and the screws are either rusted in too much or the metal too soft, the extractor just spun out
