ScampMike
Despicable Damn Yankee
ya flikkin' dingleberry - ....and it's in concert - not on concert..and yet they want 15/hr....
and it's "concert"
and it's "concert"
Yep, that's a lot more involved than the one I saw. Hardest part of that is disconnecting the battery. It is buried, not sure if I can reach it todisconnect directly. I know there are jumper points, just need to see if taking it off there is a full disconnect. I really think the actuator and door are fine and set right from what I saw last night, but worth a try . Still a lot easier than messing with the core or even the lines into it that are directly behind the engine.OK, Here's what you need to do...
The Actuator Calibration homes and repositions the air-door actuators and removes accumulated positioning errors. This can be done using a Star Scan tool (Dealer) or can be forced by the following process:
With the vehicle on and running (doors closed):
1. Turn the air temperature controls to the lowest (cold) setting for each side and wait for 30 seconds before proceeding.
2. Turn the main system control to the full "off" position and fan to the lowest setting.
3. Turn the vehicle off
4. Wait at least 5 minutes, then disconnect the battery, wait at least 5 minutes, then reconnect battery.
5. Restart the vehicle
6. Turn the main system control to "floor", turn fan to medium setting and wait for system to fully redirect the air flow to the floor.
7. Turn the air temperature controls to the highest (heat) setting for each side and wait for 30 seconds before proceeding.
8. Turn the main system to "vent" and wait for system to fully redirect the air flow.
9. Turn the air temperature controls to the lowest (cold) setting for each side and wait for 30 seconds before proceeding.
10. Turn the main system control to the full "off" position and fan to the lowest setting.
11. Turn the vehicle off, exit vehicle, close the door and lock vehicle.
The system should now be reset to base calibration and all "learned door position" data cleared.
and its on drugs not in drugs...ya flikkin' dingleberry - ....and it's in concert - not on concert..
but it can always be on bed or in bed...and its on drugs not in drugs...
it's flikkin' because I said so!!*flicking
well I guess we should expect that. I mean the chebbie hood on a mopar proves you do things wrongit's flikkin' because I said so!!
fixed itwell I guess we should expect that. I mean the chebbie hood on a mopar proves you do things your own way
Yep, this is the 1st attempt, result is just above hammered sh$t IMO, but with more careful measurements, it will work. Four pieces per side, that takes a longer attention span than I have today. Next!!Nah, David is making a replacement part for the perforated outer part of the grill on his Fury.
well, it appears David @goldfish65 has pulled a Chris on us... tossed up a challenge image (hey, whats this!?) and then nothing... just left us all hanging
Nope, you have to disconnect the battery itself for it to work. There are multiple power distribution paths from the battery so it must be disconnected to fully kill the vehicle power. Just be sure to always disconnect the negative cable first, then the positive cable so that you don't get any arching that can destroy modules.Yep, that's a lot more involved than the one I saw. Hardest part of that is disconnecting the battery. It is buried, not sure if I can reach it todisconnect directly. I know there are jumper points, just need to see if taking it off there is a full disconnect. I really think the actuator and door are fine and set right from what I saw last night, but worth a try . Still a lot easier than messing with the core or even the lines into it that are directly behind the engine.
you wouldn't maybe be having a glass or two of birthday wine while you're at would ya?LOL cut me some slack Mike, poking holes in aluminum takes time
See I am a legend.well, it appears David @goldfish65 has pulled a Chris on us... tossed up a challenge image (hey, whats this!?) and then nothing... just left us all hanging
Hey David, why not just get some metal tape and poke the holes in that? It would be easier to do, can be cut to the actual pattern of the space (make a paper template first), it's self adhesive and you can paint the background black before applying it so it will look like the other parts of the grille.LOL cut me some slack Mike, poking holes in aluminum takes time
a legendary PITASee I am a legend.
oh sure - wait 'til he's about done THEN throw out a new idea...Hey David, why not just get some metal tape and poke the holes in that? It would be easier to do, can be cut to the actual pattern of the space (make a paper template first), it's self adhesive and you can paint the background black before applying it so it will look like the other parts of the grille.
But still a legend hahahaa legendary PITA
just waking up from your winter slumber?G'day folks
yep, Taking it easy today , back is acting up. Climbed under my FIL car last night to put a hitch on so he can carry his motorized wheelchair.just waking up from your winter slumber?
lol, yeah, my girl likes to volunteer me......no good deed goes unpunished
