Ddaddy
I'm changing the World... one pixel at a time!
That would be cool! But with my luck, I'd sneeze while operating the remote control and drive it into one of the cars.
Maybe I just need to invest in a heated driveway...
Salt or heat... Takes a lot to melt even a couple inches of snowOr a bag of salt
I've got 150 lbs of salt. It won't work on 6" of sleet with an inch on ice on top. It barely makes a dent. Salt also stops working at 15° F.Or a bag of salt
Again, tell Mother Nature to send it to meI've got 150 lbs of salt. It won't work on 6" of sleet with an inch on ice on top. It barely makes a dent. Salt also stops working at 15° F.
Yeah, my driveway is actually at the perfect slope for a heating system and the drainage at the street is ideal to take it away without causing icing issues. I really should see if I can get a quote and decide if it's worth it or not.I was going to suggest that.. But be sure to install good drainage or some butt crack neighbor will try to sue you cause they slipped on ice you created
Wouldn't that just be the most ironic thing everI was going to suggest that.. But be sure to install good drainage or some butt crack neighbor will try to sue you cause they slipped on ice you created
PleaseChris wants snow... What you need is a transporter that will dump it in his yard
there you go - even salt requires work - heat just requires some $ and a flip of a switch!Yeah, my driveway is actually at the perfect slope for a heating system and the drainage at the street is ideal to take it away without causing icing issues. I really should see if I can get a quote and decide if it's worth it or not.
You tell her, I don't need to do it for you!Again, tell Mother Nature to send it to me
I've been begging her for months.You tell her, I don't need to do it for you!
Once daughters learn that one, they use it forever. My daughter still makes a point of saying it to me several times a day.Awe I may just cry. My 3 year old has learned a new phrase. "I love you Daddy"
Hey did you happen to see that Holset sign?
I was helping a retired Cummins turbo engineer move a couple years back and he was on the turbo test team, he gave me one, he had a whole box. I wished I'd taken more lol just don't see them around much.I did. Where did you find that?
I wish I had taken the boxes of Citgo and Jenney signage my grandfather had from his service station when they sold it. He had dozens of signs from all sorts of products.I was helping a retired Cummins turbo engineer move a couple years back and he was on the turbo test team, he gave me one, he had a whole box. I wished I'd taken more lol just don't see them around much.
Not that Jenny...this Jenney!
