Happy birthday Keith!
Banner just for Keith! Cool coffee beans!
Looks like my throttle cable bracket will be here today! Last really needed piece, I did have to get a vac reservoir for the brakes I did not think of during the build, Only have 11 at idle.
I got one from summit, has the check vale like on the booster. Just need to get the rest of the steering back in to see where to mount it.
http://www.summitracing.com/parts/sum-g1464/overview/
:cheers: A day set aside just for you Cheers :coffee2::coffee2:Morning all!
On days I don't have to work, I sleep in until 5am!!!
But if you add another reservoir, you may need to "protect" that vacuum with a check valve so it can't be sucked away from the brakes.
I used to design vacuum lines for Jeep for three years... We always put a check valve in to protect the brakes...
Morning JLR!
The can has a check valve and so does the booster, where else do I need one? Am I lost so early in the day?
Memi, when are you changing out the rear?
Morning!
Day started great...email from FedEx say my parts are coming today!
Gotta love that!
When my son has time to get Victoria to my friends shop down the road, plasma cut holes for super comp fender well headers and do the rear end , he has to complete the house he started framing last Friday, your guess is as good as mine at this point.
I was going to put the line from the engine onto the cans check valve then run a line to the brakes check valve. Wont that work?
Re direct them to Keith it is his birthday! LMAOops:
