Hey Ray !!
Yea, she said you did, she is looking forward to seeing something she can buy from you :color:Hang in there Memi it will all work out. Sent Treva some pics now I know what she is looking for.
Morning all again ! Great day here cool night sunny day today and no so hot.
I am sure there is stuff around here now that I know what she uses. Helps me get rid of stuff and get rid of my paypal balance since the brake episode. Got the vac pump late yesterday and the Mildon dipstick so should be on the road safely this weekend. Did you see if you have the pulley? I started cutting the third grove off the one I have Should drink a lot when doing that type of surgery. Fnd out the converter bolts were in but the transfer case was in N. Found that out when I mounted the shifter, did not even think of that one. The TT is getting there, slowly.
Yea I have been trying to get more sleep,...
The big one? The main one is a bypass hose? I thought that was like a vent, this is the main one that connects the two main tubes the size of a radiator hose.
Just did not know the name. When are you free to get the engine? Or if you want I can drop it off when the truck is running?
You know you need coffee when... It doesn't matter how bad the coffee is and you still drink it black. :coffee2::coffee2:
Tell you what if the pop runs good for a few hundred I will throw it on the trailer and go for a ride. You want the 904 also? Could use a rebuild but runs ok. 106k on it as far as I know.
