Hell I'll throw a party. I want someone to actually beat the Patriots in the superbowlWhat will happen when you guys win the Super Bowl?
What year?Man the Dakotas are definitely lacking aftermarket sheetmetal.
Wrong @Mopar TimThink you can find these cab mounts 2002 Dakota 4 door cab. Possibly just cut the floor out around them? The frame mounts are actually good.
View attachment 1715133013 View attachment 1715133014
Tim, I bought one for my 68 GTS, 68 only. I found a guy in So Cal. that had one restored and re anodized, but not painted. I got it for $600, so , yes they are very expensive. Still have to detail paint this one...The one on my 69 has been restored, BUT after washing yesterday, some of the black paint is chipping off. I guess I can repaint it. Thanks...
i edited out the wrong one for ya. Poor guy , I've done that a dozen times. He must be sick of getting confused with our TimmyLOL fixed it kind of!
So just the cab mounts, both sides? Year?
Mine is good, just needs some touch up, want to do it right the first time.Tim, I bought one for my 68 GTS, 68 only. I found a guy in So Cal. that had one restored and re anodized, but not painted. I got it for $600, so , yes they are very expensive. Still have to detail paint this one...
I'm sure there are a few here in Pic A Parts.Man the Dakotas are definitely lacking aftermarket sheetmetal.
Eagles beat the Patriots in the super bowl? The earth will stop turning....IMO. Never happen... And I WANT Shady Brady to lose...What will happen when you guys win the Super Bowl?
Hey, about time you get some snow there.Morning, on this snowy Monday morning. Got about 6 inches.
I was just thru there a few weeks ago, they were making snow in Aspen and Vail!Yep, we are a little dry around here. Mountains did get thumped though.
i agreeEagles beat the Patriots in the super bowl? The earth will stop turning....IMO. Never happen... And I WANT Shady Brady to lose...
How much machining you need to do on a block has a lot to do with how much power you are considering making with it. A stockish street 440 probably does not need to be decked, just checked, factory specs were horrible... If you don't deck it, might not need to line hone it... IMO.So, 440 block that was in question has been dropped off at a new machine shop this morning. Guy is going to inspect it for me, for free and give me one last opinion before I decide what to do with it. To refresh memories, original machine shop failed to deck it, line hone it, didn't hot tank it. They did bore and hone it and improperly install the cam bearings. I've taken it to 2 other shops since and have gotten split decisions, one saying the block is trash and the other saying the bores and hone job are fine and within specs and that they could finish the job. So we shall see today.
well that's why I'm having it checked. Here's the thinking. I have a virgin, 1970 440 block that's in decent shape and i have this 73 block, with balanced rotating assembly and L2335 forged pistons. Original plans were copying a build from a well known member here that netted over 550 hp with heads that flowed roughly what the new trick flows do. but that required a 0 deck. So now that I have the polara and depending on the condition of the Poly 318, since the 73 block was NOT decked, I could throw a set of used, but good 906 factory heads on it and make a tad over 400 hp and put in the polara and then start over with my 440 build with the 70 block since its a virgin block. Considering body work will take me another year on the dart, this may end up being the best solution anyway. But it depends on IF the 73 block is usable. The polara, I'm just screwing down sheet metal to the floor boards and making the suspension and brakes safe to drive. then its a cruiser from thereHow much machining you need to do on a block has a lot to do with how much power you are considering making with it. A stockish street 440 probably does not need to be decked, just checked, factory specs were horrible... If you don't deck it, might not need to line hone it... IMO.
Just click buy it now. LOLwell that's why I'm having it checked. Here's the thinking. I have a virgin, 1970 440 block that's in decent shape and i have this 73 block, with balanced rotating assembly and L2335 forged pistons. Original plans were copying a build from a well known member here that netted over 550 hp with heads that flowed roughly what the new trick flows do. but that required a 0 deck. So now that I have the polara and depending on the condition of the Poly 318, since the 73 block was NOT decked, I could throw a set of used, but good 906 factory heads on it and make a tad over 400 hp and put in the polara and then start over with my 440 build with the 70 block since its a virgin block. Considering body work will take me another year on the dart, this may end up being the best solution anyway. But it depends on IF the 73 block is usable. The polara, I'm just screwing down sheet metal to the floor boards and making the suspension and brakes safe to drive. then its a cruiser from there
My birthday is Friday... hint hintJust click buy it now. LOL
MOPAR DODGE 512 - 642 HORSE COMPLETE CRATE ENGINE/PRO-BUILT/ 426 440 528 NEW BBM | eBay
Un believable how much they want for engines! Freakin machine work costs have gone thru the roof!Just click buy it now. LOL
